Does Caliper Pin Boot Over Bolt Or Sleeve?
by Fitz98 - 02/20/20 03:11 PM
Costco requiring membership for food court
by WhyMe - 02/20/20 02:56 PM
Next Tesla OTA Update - Street Lights
by JeffKeryk - 02/20/20 02:49 PM
Robocalls stopped for now...
by rekit - 02/20/20 02:27 PM
Pennzoil 0w30
by Eddie - 02/20/20 01:55 PM
Using an upper cylinder lube for lean running engine?
by dunlop0078 - 02/20/20 01:45 PM
New Ford Escape...1.0 liter...really?
by grampi - 02/20/20 01:34 PM
I need information on these filters
by 4fordsd - 02/20/20 01:18 PM
WashZilla
by John_Conrad - 02/20/20 12:56 PM
Continental WinterContact TS870
by SubLGT - 02/20/20 12:52 PM
What sort of ATF and is Merc V synthetic?
by Stinky123 - 02/20/20 12:37 PM
Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
AAIRCraig, Jason454, Max331, 4fordsd, Mayberryminitruc
70760 Registered Users
118 registered members (4fordsd, 53' Stude, 2009Edge, andyd, 28oz, 15 invisible), 2,191 guests, and 15 spiders.
Topics301,710
Posts5,201,087
Members70,760
Page 41 of 44 1 40 41 42 44
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: Gokhan] #5049332 03/20/19 07:46 PM
ekpolk Offline
Global Moderator
Global Moderator
Thirteen pages . . . and still in search of a "final verdict"! Our court system does better than this!!!
This one's officially nominated for the "Most Ironic Thread Name Ever on BITOG" award.
18 Prius Two-Eco (L-Ion Batt), Mag Grey, 4000 miles (M1 AFE 0W-20).
07 Avalon XLS, Cassis Pearl, only 70k miles (M1 EP 5w-30).
04 Prius, Black, 200k miles (M1 EP 5w-30). 2006-2019 --RIP 😥
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: Shannow] #5049471 03/21/19 02:20 AM
G
Garak Offline
G
Yes, Shannow, and I posted a spreadsheet ages ago with error analysis, as you recall, that showed the same thing. If I can't tell the difference between very high HTHS CJ-4 Delvac 1 versus an ILSAC 5w-30, then this won't wash, either.
Plain, simple Garak.
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: ekpolk] #5050213 03/21/19 05:05 PM
G
Gokhan Offline OP
G
Yes, the eternal thin vs. thick debate.
Plus, a new debate also covered in this thread -- Thin vs. thin: PAO vs. inferior base oils.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 4,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: Shannow] #5050222 03/21/19 05:13 PM
G
Gokhan Offline OP
G
Originally Posted by Shannow
You can't claim that resolution tank to tank...
Here's my Colorado, all 2.5 tonnes of it, filled typically at the same bowser, with the same "run to click", count to 20 to release air bubbles, then run half speed to next click...every time).
As you can see the variability is far beyond the resolution that you are claiming tank to tank.
I would certainly not argue against it.
These are good MPG numbers. Do you have the 4-cylinder or V6? Mostly highway driving, I assume?
Here is my data, since I started recording it. I try to use the same pump and park in the same position as much as I can. Then, when done, I wait for ten seconds and push the nozzle in a couple of times.
[Linked Image]
TGMO 0W-20 SN vs. M1 0W-40 SN MPG comparison is probably misleading because my driving conditions were somewhat more short trips and city driving with TGMO 0W-20 SN than with the M1 0W-40. The MPG study is definitely not a controlled one and the average numbers shouldn't be interpreted absolutely.
One thing that is striking tough, you don't see as many data points with TGMO 0W-20 below 20 MPG than you do with M1 0W-40. It seems to indicate that when it comes to city driving and short trips, a thinner oil is a clear winner. There is probably not a striking difference in highway driving though.
Yes, so far only two data points with M1 EP 0W-20 and the car saw more highway driving than typically seen with TGMO 0W-20. However, I'm really familiar with this car and there seems to be an improvement in fuel economy. The new air filter (and spark plugs, although the old spark plus were still in good shape) may also be affecting it somewhat.
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: Gokhan] #5050244 03/21/19 05:39 PM
PimTac Offline
This thread is like a Godzilla movie. Just when you thought you killed it, it returns.
PAO versus inferior base oils. Was that before or the sequel to this thread? Inferior is a harsh word. PAO is not the end all to be all.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: Gokhan] #5050323 03/21/19 07:09 PM
2015_PSD Offline
I got a very nice 29.0 MPG in mixed driving in my first tank.
Update: 27.0 MPG in mostly city mixed driving in my second tank. This is far better than what I was getting before. Sure, the new air filter could have made a difference, but the PAO-based M1 EP 0W-20 SN PLUS is a very low-friction oil from how the engine sounds and feels.
Since this was not conducted in a laboratory under controlled, repeatable conditions, we can safely assume that as a minimum the following variables exist:
-- Climate (temperature, relative humidity, barometric pressure)
-- Driving conditions (traffic patterns, time of day, your driving skills, locations)
-- Fuel (different batches, average octane, fill levels)
-- Vehicle (tire pressure, load, condition)
So with all of that as a minimum in the number/types of variations, you are stating the air filter may have made a difference, but more certainly, the oil did because it is low-friction (suggesting it is lower friction than other xW-20 oils) based on how the engine sounds and feels and the oil is the primary reason your MPG increased?
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Mahle]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: Gokhan] #5050336 03/21/19 07:27 PM
Z
ZeeOSix Offline
Z
[Linked Image]
Two data points with M1 EP 0W-20 ... clearly not enough data yet with that oil.
Also no real difference seen between M1 0W-40 and TGMO 0W-20... too much scatter to make any real trend conclusions.
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: Gokhan] #5050549 03/22/19 03:25 AM
G
Garak Offline
G
I'd also add that the only figure I'd have real confidence with respect to having four significant figures is the price spent at the pump, given that the uncertainty should only be rounding up or down to the nearest penny. Everything else is a stretch beyond 2 or 3.
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: ekpolk] #5051136 03/22/19 03:18 PM
N
NGRhodes Offline
N
Not forgetting this started as a which protects better but is now talking about which gives better MPG.
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: Gokhan] #5051166 03/22/19 03:51 PM
Direct_Rejection Offline
I have found M1 EP 0W20,
with its high PAO base stock,
to cause my engine to be the noisiest.
Conversely, Pennzoil Gold 0W20,
with its Group II & Group III,
not even GTL base stock,
to cause my engine to be the quietest.
Good add pack
meet the specs
for the win.
2019 Lexus UX 250h F-Sport
TGMO 0W16
@ 34k miles
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: Direct_Rejection] #5051189 03/22/19 04:07 PM
O
OVERKILL Offline
O
Good add pack
meet the specs
for the win.
So your engine prefers the sound deadening effects of plastic grin
In all seriousness though, the VII treat rate on M1 EP will be a small fraction of what it is in that Pennzoil Gold product because it will be blended with heavier bases. It's quite possible that the acoustic characteristics of VII polymers are favourable in this scenario and is the reason for your observations.
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: ZeeOSix] #5051200 03/22/19 04:24 PM
2015_PSD Offline
Agreed; 1/10 of a point between a xW-20 and a xW-40 oil from a single comparison related to MPG is statistical background noise at best and goes a long way in pointing out what this "experiment" and the "results" actually are.
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: OVERKILL] #5051250 03/22/19 05:50 PM
G
Gokhan Offline OP
G
Here is my latest A_Harman index table. The column labeled "VII" is equal to 1 - A_Harman index and it's an approximate measure of the viscosity-index improver (VII) content, even though technically it represents the VII temporary shear at 150 C temperature and 1,000,000 per second shear rate.
[Linked Image]
Now, surprisingly, Pennzoil Gold 0W-20 virtually ties with M1 EP 0W-20 in (lack of) VII. In fact, I assumed HTHSV = 2.6 cP for it and if HTHSV is higher, it would readily beat M1 EP 0W-20. M1 EP 0W-20 is only second to M1 ESP x2 0w-20 (an MB 229.71/ACEA C5 oil), which, along with M1 AP 5W-20, has less VII than any oil listed here except for the monograde Amsoil 30 (also qualifies as a 10W-30), VAS 5W-20, and Delvac Super 1300 15W-40.
So, it's hard to believe that Pennzoil Gold 0W-20 is a synthetic blend. It's possibly a full synthetic. It readily beats PPPP 0W-20 and PUPPP 0W-20 in VII content.
Regarding how the engine sounds, well... I really like how M1 EP 0W-20 SN PLUS sounds in my engine. Who knows, perhaps I'm hearing the metal grinding away, but I like the sound. wink It sounds like the engine has lower friction with it in my perception but if some interpret it as the engine being louder, which I didn't notice, it could be more of a perception issue than a scientific observation, until people grab sound-level meters and start scientific observations.
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: Gokhan] #5051318 03/22/19 07:07 PM
O
OVERKILL Offline
O
I think we need to hit pause here for a second. Does it not strike you as odd that M1 EP 0w-20 would have a 5.5% VII treat rate and its sibling, AP 0w-20, which has the same amount of PAO, is 10%? Both have almost identical VI's too. Doesn't smell right to me shrug Also, AP Flash point: 242C, EP? 235C. I'm guessing the HTHS for both of these lubes is rounded. AP could be 2.64 and EP could be 2.65 for example, and that's skewing the calculations.
Playing around with the calculator using the above theory:
EP:
A_Harman Index: 0.926
AP:
A_Harman Index: 0.913
BTW, I noticed you used the KV40 for AP 0w-20 from the MSDS. I'd be hesitant to do that and here's why:
The MSDS for EP 0w-20 lists:
KV100: 8.4cSt
KV40: N/A
Flash: 235C
Pour: -45C
The MSDS for AP 0w-20 lists:
KV100: 8.7cSt
KV40: 45.7cSt
Flash: >200C
Pour: -45C
We know that the Pour Point is wrong for both of them. KV100 is wrong for EP and KV40 isn't even listed. So I'd be skeptical of that number IMHO. I'd wager both have basically the same VII content and the deviation we are seeing here is the result of rounding.
For Pennzoil Gold "blend" 0w-20 BTW, I think your sniffer is working properly. The MSDS shows 70-90% GTL LOL
I'm going to say that the lack of digits after the decimal for the KV values is, at the resolution we are trying to achieve here, screwing us, for example, using the Gold w/HTHS 2.6:
KV100 8.44, Index becomes 0.937.
If rounding is allowed in HTHS, IE 2.58 can be rounded to 2.6 then that adds another layer of fudge factor here smile
Re: Thin or thick (TGMO 0W-20/M1 0W-40): Final verdict [Re: Gokhan] #5051344 03/22/19 07:28 PM
O
OVERKILL Offline
O
BTW, another thing I find interesting is that for the Gold 0w-20, the Pour Point is -48C. Given it is basically entirely GTL based, that points to a very light base oil and a significant dose of PPD. Even Yubase 4+ only has a PP of -15C:
https://www.repsol.com/imagenes/global/en/base_oils_gii_giii_tcm14-19328.pdf
Would be really nice if we had Noack...
