This UOA was for two OLM cycles. The full flow filter changed with each cycle and makeup oil added to fill the new filter. Engine also has Amsoil bypass filter that is changed every other oil change (so 4 OLM cycles). Oil was Delo 400 LE 5W40 synthetic. Full flow filter is Motorcraft.
I am thinking I could go three OLM cycles rather than two.
Code
oil Delo T6 T6 T6 Motorcraft
mileage 89588 64385 56820 48937 41160
mileage on oil 15460 7565 7883 7777 7480
Metals
Fe 27 11 14 17 15
Cr 1
Pb
Cu 3 2 2 3 2
Sn
Al 6 2 5 7 8
Ni
Ag
Ti
V
Contaminants
Si 10 9 6 7 8
Na 13 4 9 9 7
K 6
Water%
Coolant no no no no no
Additives
Mg 1109 1090 1166 944 21
Ca 791 889 915 996 2155
Ba
P 879 1102 1141 1034 892
Zn 1163 1375 1305 1189 985
Mo 61 67 65 57 5
B 17 38 42 45 42
Physical tests
Vis (cSt 100C) 13.1 12.6 11.5 12.6 10.0
Fuel %
Soot % 0.05 0.1 0.2 0.9 0.3
Physical/Chemical
TBN 5.9 7.1 8.1 7.5 5.9
Code
Metals
Fe 27 11 14 17 15
Cr 1
Pb
Cu 3 2 2 3 2
Sn
Al 6 2 5 7 8
Ni
Ag
Ti
V
Contaminants
Si 10 9 6 7 8
Na 13 4 9 9 7
K 6
Water%
Additives
Ba
Mo 61 67 65 57 5
B 17 38 42 45 42
Physical tests
Fuel %
Physical/Chemical
