2003 Ford CVPI, 96kmi, 10kmi on Pennz HM 5W30
by Colt45ws - 11/11/19 07:24 PM
Amsoil Upper Cylinder Lubricant
by Donald - 11/11/19 06:41 PM
Pfft.. piece of cake!
by Mad_Hatter - 11/11/19 06:17 PM
Garage door lack of signal/reception issue
by dja4260 - 11/11/19 06:05 PM
low voltage triggers abs and parking brake light?
by motor_oil_madman - 11/11/19 06:03 PM
Kendall GT-1 MAX 5W30 2017 Crosstrek
by Voleak - 11/11/19 05:51 PM
Wife’s Oil Change
by KevGuy - 11/11/19 05:48 PM
AZ $10 off of $50
by BlakeB - 11/11/19 05:41 PM
B&S riding mower long filter short filter etc.
by j_mac - 11/11/19 05:32 PM
Covering the cowl vent
by painfx - 11/11/19 05:31 PM
Project: DuckHead Arm
by RayCJ - 11/11/19 05:29 PM
I Found The Perfect Garage Door Oil
by billt460 - 11/11/19 02:03 PM
Oil recommended for Old Snowthrower
by Ckerch - 11/11/19 01:58 PM
Choo Choo train maintenance and repairs?
by Chris142 - 11/11/19 01:58 PM
Hemi Oil Use
by Zap1967 - 11/11/19 01:27 PM
Who Makes the Best Class 8 "Semi" Truck These Days?
by LoneRanger - 11/11/19 01:21 PM
Update to my Wide Open West Broadband Thread
by LoneRanger - 11/11/19 01:15 PM
greenmeanie, vw_sod, Mac87, LazyJ, Danohall
69832 Registered Users
131 registered members (2010Civic, aquariuscsm, 53' Stude, ABursell, ArrestMeRedZ, amblerman, 11 invisible), 2,120 guests, and 21 spiders.
Topics297,286
Posts5,112,273
Members69,832
Most Online3,589
Nov 2nd, 2019
When to send in oil for testing? #5049228 03/20/19 05:12 PM
SnowDrifter Offline OP
Trying to get a feeler here. Had my oil pan and timing cover off, replaced oil pump while I was in there. New gaskets, new metal parts. I realize this will vary a bit from vehicle to vehicle, but what's a good waiting period for silicon, break in wear metals, etc to sort themselves out?
2005 Tahoe - 140k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: When to send in oil for testing? [Re: SnowDrifter] #5049240 03/20/19 05:30 PM
SirTanon Offline
Depends on what you're going for and if you plan on getting regular UOAs to continue tracking trends. When I had the head off on my Fusion for valve work, etc.. I started doing UOAs from the next oil change onward. It has proven a great way to continue tracking the engine following the work.
2013 Nissan Altima SV - 2.5 liter/CVT - 123,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 69,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: When to send in oil for testing? [Re: SirTanon] #5049248 03/20/19 05:37 PM
Admittedly I've not done any tests on this rig yet. But since the oil pump I installed was high pressure / high volume, I want to play around with different oil viscosities to see see if one gives better results than the other. Can't do that while material is shedding though! The pump gives me a fair bit more wiggle room, both to not lose pressure in the Xw20 territory, and not lose flow if I'm going thicker.
2005 Tahoe - 140k
Re: When to send in oil for testing? [Re: SnowDrifter] #5051552 03/23/19 03:38 AM
L
Lubener Offline
L
When you change your oil next, doing it sooner is a waste of time.
The "thinking" man's friend.
