CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
2004 FZ6 Delo 400
by thestockie1 - 03/30/20 04:34 AM
rider9195, kingsville911, B34R, ChrisSnowden, DIY4quality
71055 Registered Users
109 registered members (2009Edge, 2010Civic, 53' Stude, aquariuscsm, ArrestMeRedZ, 4WD, 15 invisible), 1,881 guests, and 22 spiders.
Topics303,359
Posts5,234,744
Members71,055
Problems After Adding 2 Stroke To Diesel #5048307 03/19/19 07:47 PM
I
InfernoRedBeast Offline OP
I
I have read just about everywhere that many people are adding 2 stroke TCW3 to their diesel. So i decided to try it in my 2006 Dodge Cummins at a mixture of 1 oz per gallon which seems to be the going mix rate. After adding it i could tell that the engine was quieter and was very happy. After running it through 2 tank fulls one day after a drive i got home, put it in park and it was bucking like it was running off 3 cylinders. Really ruff idle. I have not used it sense. Truck still does not seem to idle as smooth as it used to. Do not know if it has anything to do with the 2 stroke but am just wondering if anyone else has had any problem with running 2 stroke in their diesel?
Re: Problems After Adding 2 Stroke To Diesel [Re: InfernoRedBeast] #5048314 03/19/19 07:55 PM
SubieRubyRoo Offline
Two things. I haven't heard of a dose rate that high, normal mix is 640:1, or about 1 ounce per FIVE gallons of fuel. Second, did you add it and then nothing else between when it started running rough, or did you add fuel in the meantime? It sounds more like that, to me. I'd change your fuel filter and see if it's buggered up with anything, and for good measure use a can of Liqui-Moly Diesel Purge as directed on the can.
Considering the seeming thousands of people who have used TCW3 without problems, I doubt yours is 2-stroke related. Which TCW3 did you use?
De omnibus dubitandum.
Re: Problems After Adding 2 Stroke To Diesel [Re: InfernoRedBeast] #5048317 03/19/19 07:58 PM
doitmyself Offline
The following peer reviewed paper says that the common amount to add per gallon is about 0.6 ounce. It goes on to not recommend the practice for numerous reasons such as valve damage and injector clogging.
https://www.fuelexpert.co.za/2-stroke-oil-in-diesel-technical-study.php .......Maybe you just need to clean the system up (injectors, etc.).
Re: Problems After Adding 2 Stroke To Diesel [Re: InfernoRedBeast] #5048323 03/19/19 08:04 PM
2015_PSD Offline
What problem are you attempting to solve? Lubricity or something else? I have seen posts in various diesel forums about adding TCW-3 oil to a tank of fuel to increase lubricity and the claims about how much it helps. I have also seen posts claiming just the opposite and how it can harm the DPF over the long term (though your 2006 is "pre-emissions" and should not have a DOF). Though situated in South Africa, this 2-Stroke Oil In Diesel A Technical Study seems to be very straightforward and analytical in its approach and gives some good insight into the lubricity of two-stroke oil in diesel fuel.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Hastings]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Problems After Adding 2 Stroke To Diesel [Re: InfernoRedBeast] #5048326 03/19/19 08:06 PM
I
I
I am in the process of cleaning the system with Hot Shots Diesel Extreme. With my searches mopar1973man kept coming up so this is the advice i used. https://mopar1973man.com/cummins/ar.../adding-2-cycle-oil-to-diesel-fuel-r357/ .... Hopefully she cleans out and starts to idle like it used to.
Re: Problems After Adding 2 Stroke To Diesel [Re: InfernoRedBeast] #5048328 03/19/19 08:08 PM
I
I
2015_PSD I was worried about lubricity. So that is why i decided to try it. And like i said it did make it seem to run quieter.
Re: Problems After Adding 2 Stroke To Diesel [Re: InfernoRedBeast] #5048333 03/19/19 08:21 PM
I
I
SubieRubyRoo
The only times i added the 2 stroke is when i filled up. I would add it before i added the diesel. I used Walmart super tech tc-w3 Outboard. I have changed both my factory and my lift pump filter sense it started running ruff. Factory filter looked good. Lift pump filter is a spin on so i could not see the condition of it.
Re: Problems After Adding 2 Stroke To Diesel [Re: InfernoRedBeast] #5048337 03/19/19 08:23 PM
Chris142 Offline
I run roughly 1oz per gallon of fuel in mine for lubrication reasons. Never had anything weird happen.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Problems After Adding 2 Stroke To Diesel [Re: InfernoRedBeast] #5048341 03/19/19 08:24 PM
M
maintenanceMan Offline
M
The problem is likely separate from your dosing. Many of us having been doing this for a long time(over 20 years) on various platforms with no such issues.
Re: Problems After Adding 2 Stroke To Diesel [Re: InfernoRedBeast] #5048346 03/19/19 08:26 PM
I
I
Yeah Chris142, i have seen a lot of people that have run that mixture with no problems.
Re: Problems After Adding 2 Stroke To Diesel [Re: maintenanceMan] #5048361 03/19/19 08:39 PM
I
I
Yeah maintenanceman guessing it is just a coincidence that it happened after only 2 tanks after starting the 2 stroke. Just my luck. I'm going to run just the cleaner in the diesel and see if it clears up.
Re: Problems After Adding 2 Stroke To Diesel [Re: maintenanceMan] #5048363 03/19/19 08:40 PM
I
I
What dosing do you run maintenanceMan?
Re: Problems After Adding 2 Stroke To Diesel [Re: InfernoRedBeast] #5048441 03/19/19 10:07 PM
CDX825 Offline
Been running one ounce per gallon in my diesel truck for years without issues.
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Mazda B2600 4x4 Amsoil Series 3000 5W30
1998 Ford Ranger 4x4 Pennzoil Platinum 5W30
Re: Problems After Adding 2 Stroke To Diesel [Re: Chris142] #5048453 03/19/19 10:32 PM
L
Linctex Offline
L
Same.
I run 128:1 in every diesel engine I own - have been since 2006 (13 years) and never any problems.
In some of them, I run 40:1 to 50:1 used engine oil.
NONE of my 9 diesel engines are "emissions controlled"
Re: Problems After Adding 2 Stroke To Diesel [Re: InfernoRedBeast] #5048531 03/20/19 01:59 AM
B
berniedd Offline
B
Another user here of 2Stroke oil added to my diesel for years without issue. An ounce for every gallon fuel. I stopped 2 years ago, only because we now have 2% biodiesel and I understand the mix now has enough lubricity and I can do away with the 2T oil.
