Originally Posted by Pinoak
Frams filters have gone up across the board in all the Walmarts around here. They are now essentially the same cost as m1 for the fu.
So now you have a filter that isn't great in price is made cheaply with an ultra thin metal can.
And what proof that these "ultra thin metal can" filters are a problem? And how are they made cheaply?
Quote
I guess they can keep marketing by the claimed filter efficiency. which is, hmm who even knows the truth about it really and does it even really matter.
So they are lying on their filtration numbers, and I guess anyone that publishes their filtration specs are lying also?
Quote
I suppose they can carry on about a wire backing because well it sounds good. But in reality it just means the media cannot keep a sufficient structure on it's own so it needs a backing.
What an ignorant comment. The media can not stand against the force of the oil flow, so it is reinforced so that it can work properly. Why is that an issue?
Quote
My point is-whats the point really in buying fram anymore?
For you, apparently none. For others, a quality filter that is still cheaper than other equal filters (Amsoil and Royal Purple are the only other 2 that are equal IMO).
And if Fram is going up due to steel cost as mentioned above, then others will be going up soon as well.
Quote
Quote
Quote
