Applications for a new job
by 97prizm - 03/28/20 02:55 AM
Petro Canada 20L bucket
by MalteseFalcon - 03/27/20 11:34 PM
Toolbox corrosion protection
by buck91 - 03/27/20 09:39 PM
Milwaukee 2767-20 Impact Wrench
by Wolf359 - 03/27/20 09:38 PM
Economic choices?
by buck91 - 03/27/20 09:33 PM
Stripped Bolt...best extractor set?
by TXCarGeek - 03/27/20 09:27 PM
HF Charger barely lasted a year
by jayjr1105 - 03/27/20 08:52 PM
My dog is not doing well.
by Chris142 - 03/27/20 08:40 PM
head rest stain. how to get out
by WhyMe - 03/27/20 07:50 PM
Heavy fuel oil: can we talk about it?
by 53' Stude - 03/27/20 07:35 PM
ramping up production of something
by andyd - 03/27/20 07:29 PM
Who waits for the RPMs to settle before ...?
by TXCarGeek - 03/27/20 06:45 PM
Signed up for Instacart
by 14Accent - 03/27/20 05:53 PM
Future Toyota Vehicle Line-Up
by The Critic - 03/27/20 04:45 PM
Brake Shoes cleaned after soaked in brake fluid?
by Cressida - 03/27/20 04:34 PM
bdowning, OliverQ50, NorCalHD, narelikg, Rhino2278
71032 Registered Users
18 registered members (bachman, Arrechera, anndel, ArrestMeRedZ, Aries, bbhero, 2 invisible), 575 guests, and 17 spiders.
Topics303,255
Posts5,232,691
Members71,032
Page 5 of 5 1 4 5
Re: Dodge Hemi Lifter/Cam failures [Re: clinebarger] #5047423 03/18/19 10:03 PM
clinebarger Offline OP
Got in tore down.....Very interesting failure mode I haven't seen.
I'll get better pic's of the lifter, The camshaft had to be sent back for a core....So I won't be able to get more of the cam.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
2001 Chevy Camaro L92/4L80E
Re: Dodge Hemi Lifter/Cam failures [Re: clinebarger] #5047425 03/18/19 10:06 PM
spasm3 Offline
Do you think the lifter ate the cam? Or did a soft cam kill the lifter?
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Dodge Hemi Lifter/Cam failures [Re: clinebarger] #5047427 03/18/19 10:08 PM
O
OVERKILL Offline
O
That's different! Where are the needles from the roller?
Re: Dodge Hemi Lifter/Cam failures [Re: spasm3] #5047433 03/18/19 10:17 PM
In the oil pan I presume
My knee jerk reaction is to blame the Lifter, But I see pits in the Lobe that went flat & some other Lobes to a smaller degree.
Re: Dodge Hemi Lifter/Cam failures [Re: clinebarger] #5047446 03/18/19 10:37 PM
spasm3 Offline
Is it just the pics, or do several lobes look worn down right here it starts to ramp up from the base circle?
Re: Dodge Hemi Lifter/Cam failures [Re: clinebarger] #5050293 03/21/19 07:49 PM
The customer approved the replacement of ONE lifter & the camshaft.
I advised the replacement of all the lifters, Removal of the oil pan to clean out the needle bearings & Oil Pump removal & inspection.....Declined as the customer is selling/trading the truck, We had him sign a warranty waiver!
I dredged the pan with a magnet through the drain plug hole & got ALL the needles out!!!! Truck is quiet as a mouse & has excellent oil pressure. I must admit.....These VVT 5.7L Hemi's run HARD!!! The transmission programming is very aggressive IMHO.
We charged him actual time (9 hours), Camshaft labor is 15 hours but I didn't pull the Bank 2 cylinder head, Oil Pan, Or the Oil Pump. Chrysler/FCA shorts mechanics on labor times compared to other brands! Toyota is on the other end of the spectrum.
The lifter will stick up into the plastic retaining trays just like a LSx engine by putting a air drill on the camshaft to knock the lifters up.
5.7L VVT engines have you use the LINK method similar to today's OHC engines, This requires removal of the oil pump & oil pan......Completely Unnecessary.
*Find TDC with a magnetic base Dial Indicator on # 1 Piston (Use cylinder #6 if you pull only the Bank 2 head)
*Set the Camshaft Phaser Gear alignment mark straight-up like shown with the chain slack on the Tension side.
*Using a suitable prybar.....Release the tensioner slowly after pulling the grenade pin.
DONE!!
[Linked Image]
[Linked Image]
Re: Dodge Hemi Lifter/Cam failures [Re: clinebarger] #5050340 03/21/19 08:30 PM
O
OVERKILL Offline
O
Great work as usual! How much was it to do the lifters? When I priced them they weren't expensive so it's surprising that he declined crzy
Re: Dodge Hemi Lifter/Cam failures [Re: clinebarger] #5050359 03/21/19 08:45 PM
spasm3 Offline
Aftermarket billet cam or oem?
Re: Dodge Hemi Lifter/Cam failures [Re: OVERKILL] #5050378 03/21/19 09:02 PM
Mopar MDS lifter Racks/Sets are on nation-wide back-order, I had to use a Melling lifter out of a Non-MDS Rack & reuse the plastic MDS retainer. I'll look at the estimate if I get a chance.....But our system may have overwritten the original estimate?
I don't deal with the numbers much at my current employ.
Re: Dodge Hemi Lifter/Cam failures [Re: spasm3] #5050379 03/21/19 09:03 PM
Mopar replacement.
Re: Dodge Hemi Lifter/Cam failures [Re: clinebarger] #5050491 03/21/19 11:29 PM
Skippy722 Offline
Are the 5.7 water pumps still on back order? I remember a couple of friends with Grand Cherokee’s and Dirango’s waiting quite awhile to get those in.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Page 5 of 5 1 4 5
