Anyone ever use this stuff? Grabbed a couple tubes yesterday as it was on sale for $1.50. Not much info on the stuff. Wondering if its ok for my little tralers bearings? One is used to bring garbage to the dump, the other one holds my little 12 foot aluminum boat. The only other thing I own with grease fittings in a Polaris atv, so 2 tubes of grease will last 3 lifetimes if it all I use it on.
This Harvest King® All Season Lith-Flex Multi-Purpose Grease is a Lithium base multi purpose grease that is especially suited for normal temperature/speed conditions and is water insoluble. It may be used for most farm applications, including chassis, water pumps and other grease lubricated bearings.
All season Lith-Flex
Temperature Range: 0°-275° F
Net Weight 14oz
Net Weight 14oz
