M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
84 registered members (bbhero, 928, AndyB, AlaskaMike, ammolab, Alfred_B, 10 invisible), 1,623 guests, and 59 spiders.
Topics286,168
Posts4,903,469
Members67,572
Most Online2,967
Mar 10th, 2019
Tire age #5040966
03/12/19 08:05 PM
03/12/19 08:05 PM
TX
rekit Offline OP
rekit  Offline OP
TX
I always thought that to a degree tire degradation was a factor of sunlight exposure, not age. The tires on a classic car stored in the garage tires would age better than a DD. Yes or no?
Re: Tire age [Re: rekit] #5040990
03/12/19 08:21 PM
03/12/19 08:21 PM
Georgia
MParr Offline
MParr  Offline
Georgia
Have you ever had a tire dealer put on tires with a brownish color to them? These are old tires that have been sitting in a warehouse for some time.
2013 KIA Optima EX 2.4L. Now: Unknown &OE filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Re: Tire age [Re: rekit] #5040997
03/12/19 08:27 PM
03/12/19 08:27 PM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
Tire degradation is affected by a whole host of things. I don't know specifics but common sense (that's not too common here sometimes) would tell you that not all environments are the same. Arizona in the sun is surely worse then Montana, stored in a garage. So it's going to be hard to know without some decent engineering studies.
Re: Tire age [Re: rekit] #5041037
03/12/19 09:11 PM
03/12/19 09:11 PM
North of you Idaho
KneeGrinder Online content
KneeGrinder  Online Content
North of you Idaho
Yes, sunlight is a major factor for tires cracking prematurely when mounted and pressurized. Stored in the garage out of daylight is much better, but still the fact that the tire is mounted, has air pressure and has the vehicles weight on them still puts a wear factor on them.
Tires not mounted, stored in the dark, no light at all will last along time, but rubber does change durometer over a long period of time, can't change that.
08 Tribeca 86k PUP 5w30 wix
06 Accord Hybrid 134k PPHM 0w20 wix
02 Chevy k3500 99k Delvac 1 esp 5w40 wix
00 F350 136k Delvac 1300 15w40 wix
Re: Tire age [Re: rekit] #5041223
03/13/19 05:10 AM
03/13/19 05:10 AM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
Heat, sunlight and air pollution are a big factors during storage.
Tires are actually tested for resistance to heat aging during storage.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W30 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport AWD 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: Tire age [Re: rekit] #5041226
03/13/19 05:23 AM
03/13/19 05:23 AM
A Warm place to live in
berniedd Offline
berniedd  Offline
Ozone and heat age tires the most.
Re: Tire age [Re: rekit] #5041266
03/13/19 06:45 AM
03/13/19 06:45 AM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
My General RTs (pre43) just turned 6 years old, and are doing quite well.
Car is garage parked most of the time, so I am sure it helps.....
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: Tire age [Re: rekit] #5041286
03/13/19 07:06 AM
03/13/19 07:06 AM
Atlanta,GA
BMWTurboDzl Offline
BMWTurboDzl  Offline
Atlanta,GA
Heat, humidity, UV exposure, and chemicals can accelerate the aging process.
435i
Re: Tire age [Re: MParr] #5041304
03/13/19 07:41 AM
03/13/19 07:41 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
Ah ….. Mmm ……. Not exactly. and it depends on what you mean by old.
That brownish color is actually antioxidants (AO's) that have done their job. When the tire is put into surface, they migrate to the surface and create this crust. The crust is a combination of the waxes and the AO's. It flakes off as the tires is used.
Some tire manufacturers use a lot of AO's, so it doesn't take very long for that crust to show up. I've seen tires as new as a year with that crust.
Heat is the big ticket item. Tires in Phoenix age a lot faster than tires in Minneapolis.
And to expand on this a little bit:
Tire aging is quite complex, so it is difficult to be precise as to how long it takes before the rubber has deteriorated to the point where it is unsafe to operate. When you hear someone say the limit is 6 years and another one says 10 years, it's because they are looking at different parts of the beast.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Tire age [Re: rekit] #5041334
03/13/19 08:25 AM
03/13/19 08:25 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
UV exposure is horrible on rubber and plastic. It's why you always see motor homes and RV's parked with those sun guards covering the tires. Leave a piece of Schedule 40 PVC pipe exposed to Arizona sunlight for a Summer. It will turn a dark purple / black on the side that faces the Sun. The other side will remain normal. It's why most all exposed PVC on swimming pools out here has to be painted, or it will deteriorate in no time.
Re: Tire age [Re: rekit] #5044443
03/15/19 08:57 PM
03/15/19 08:57 PM
Rapid City, South Dakota
littlehulkster Offline
I've wondered for a while if it wouldn't be a good idea to wipe the tires down with some 303 Aerospace protectant prior to storing them away. It's not expensive, and the stuff apparently does work quite well on rubber. I'd be worried about any oils potentially degrading the traction, though.
2015 Mazda3 I 2.0
Re: Tire age [Re: littlehulkster] #5044461
03/15/19 09:23 PM
03/15/19 09:23 PM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
I used to use 303 a lot as a tire "shine" and liked the natural look it imparted. I would NOT use it on anything tread related, though!
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Tire age [Re: buck91] #5044485
03/15/19 09:50 PM
03/15/19 09:50 PM
Yeah, I think avoiding the tread would be wise, but I wonder if a good wipedown of the rest of the tire before you stow them away would help prevent dry rot and cracking.
2015 Mazda3 I 2.0
