M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
65 registered members (bbhero, ABerns, aquariuscsm, Anduril, ammolab, 7 invisible), 1,282 guests, and 58 spiders.
Topics286,168
Posts4,903,498
Members67,572
Most Online2,967
Mar 10th, 2019
Allison Clutch Test - What is it? #5044414
03/15/19 08:29 PM
03/15/19 08:29 PM
Toronto, Canada
George7941 Offline OP
Toronto, Canada
I am attaching the two relevant pages from the Allison DOC User Manual about the Clutch Test. I do not understand what the purpose of the test is. I believe it tests the torque converter clutch. How does this test accomplish that?
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Allison Clutch Test - What is it? [Re: George7941] #5044454
03/15/19 09:12 PM
03/15/19 09:12 PM
Fort Worth, Texas
clinebarger Online content
clinebarger  Online Content
Fort Worth, Texas
Allows you to test Clutch Holding ability & Solenoid combination/Shift Valve functionality. Selecting higher than normal commanded ratios allow easier diagnosis of slipping components.
2001 Chevy Camaro L92/4L80E
Re: Allison Clutch Test - What is it? [Re: clinebarger] #5044506
03/15/19 10:16 PM
03/15/19 10:16 PM
MN
14Accent Offline
14Accent  Offline
MN
That's about it! Tip-tronic with a little more control, basically.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Allison Clutch Test - What is it? [Re: George7941] #5044592
03/16/19 12:52 AM
03/16/19 12:52 AM
Toronto, Canada
Toronto, Canada
So how would I actually test for a slipping TCC? Drive along at a steady 40mph, select 5th (Drive) in the Clutch Test Mode and then see if the engine flares up if I step on the throttle? The Engine and Turbine speeds are displayed on Allison DOC, so I could watch that to see if the clutch is slipping. Is there another better way?
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Allison Clutch Test - What is it? [Re: George7941] #5045307
03/16/19 08:06 PM
03/16/19 08:06 PM
Fort Worth, Texas
Fort Worth, Texas
I'm not familiar with commercial Non-GM Allison applications, In a GM application....There is a TCC Slip RPM data PID that tells you everything you need to know. It basically takes the Turbine speed & Engine speed & displays the differential.
Do you have TCC Slip code/s in the TCM?
Re: Allison Clutch Test - What is it? [Re: clinebarger] #5046512
03/18/19 08:57 AM
03/18/19 08:57 AM
Toronto, Canada
Toronto, Canada
Thanks for your help, clinebarger. I have very little experience with automatic transmissions, so any help is most welcome.
The subject truck is a 2006 Freightliner M2 with an Allison 2100 HS tranny. There is no TCC slip pid in the data stream. There is engine speed, turbine speed and output speed pids. Yesterday I graphed engine speed and turbine speed while driving along a 20mph with the clutch test enabled for 2nd gear and the variation with the two speeds while I stepped on the throttle indicates that the TCC was not applied.
The TCC solenoid passes the solenoid test in Allison DOC.
I don't think there are any codes in the TCM but I will check again.
Truck is not giving any issues but I was just curious as to whether the TCC was working as it should.
1987 BMW R80 - sold
2015 Honda CBR300R
