M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
92 registered members (AndyB, AlaskaMike, ammolab, Alfred_B, Aero540T, agpatel, 12 invisible), 1,652 guests, and 56 spiders.
Topics286,168
Posts4,903,469
Members67,572
Most Online2,967
Mar 10th, 2019
Page 4 of 4 1 2 3 4
Re: Do you use 5w30 in your mower? Does your mower hold 2 quarts? [Re: lawnguy] #5043319
03/14/19 09:05 PM
03/14/19 09:05 PM
out there
spasm3 Offline
spasm3  Offline
out there
I put 5w 40 mobil 1 turbo diesel oil in my zero turn. I had a jug in the garage from a WM sale.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Do you use 5w30 in your mower? Does your mower hold 2 quarts? [Re: lawnguy] #5043780
03/15/19 12:20 PM
03/15/19 12:20 PM
Ottawa, Ont CANADA
2K2AcuraTL Offline
2K2AcuraTL  Offline
Ottawa, Ont CANADA
I vaguely asked the type of question when I got my new [to me] Husq ride mower..
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4935064/will-5w30-synth-do#Post4935064
maybe another angle on the same topic..
Cheers
J.
2002 Acura TL-P --- 2013 Acura MDX-Elite
Both on PP and PP Ultra & Petro-Can Duradrive synth ATF
2007 Chev Trailblazer LT
1998 Pontiac Transsport
1984 Firebird SE
Re: Do you use 5w30 in your mower? Does your mower hold 2 quarts? [Re: mk378] #5043918
03/15/19 02:43 PM
03/15/19 02:43 PM
Michigan
jkasch Offline
jkasch  Offline
Michigan
Originally Posted by mk378
Originally Posted by Snagglefoot
Rookie Tip: On a Honda GCV you remove the the dipstick, wipe it clean, then push it in, but do not screw it in. Then pull it out and check the level. If you screw it in, you will get a wrong reading and have a low level in the crankcase. This is from the manual. smile
That's also the method for Briggs that have a long plastic filling / dipstick tube up to the top of the engine. Sometimes it is good to RTFM.
The engine manuals for my 15 year old 23hp twin Briggs Intek and Toro/Briggs Super Recycler both say to tighten the dipstick down when checking level. Has that changed recently?
Re: Do you use 5w30 in your mower? Does your mower hold 2 quarts? [Re: jkasch] #5043953
03/15/19 03:08 PM
03/15/19 03:08 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
The manual for my 18.5hp Intek says the same.
"Zed's dead baby, Zed's dead."
Re: Do you use 5w30 in your mower? Does your mower hold 2 quarts? [Re: lawnguy] #5044400
03/15/19 08:18 PM
03/15/19 08:18 PM
Ontario Canada
caprice_2nv Offline
caprice_2nv  Offline
Ontario Canada
6.5hp? Side valve Briggs and Stratton, I can't remember the capacity. I run full synthetic 5w40 in it. It burns a bit of oil. I believe the carb has been leaking gas into the oil since before I bought it used last year.
My previous 1981 Briggs and Stratton 3hp never burned oil. I ran the same 5w40 full synthetic. The engine ran great until I hit a huge bolt hidden near a sidewalk in deep grass and it stopped the engine dead and and bent the rod or crank. That motor had a ton of very hard hours on it, hit lots of rocks, going through deep wet grass, ran for hours straight only stopping when out of gas. My dad ran straight 30 conventional when I was a kid and it rarely got changed because my dad was too busy with other stuff (building the house). It didn't get good maintenance until I inherited it and fixed it up a bit.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Re: Do you use 5w30 in your mower? Does your mower hold 2 quarts? [Re: lawnguy] #5044690
03/16/19 08:29 AM
03/16/19 08:29 AM
VA
Gebo Online content
Gebo  Online Content
VA
No, never used a 5w-30 in the last 20 years in either of my mowers.
I use Amsoil Small Engine 10w-40 and oem oil filters
in my Honda and Kawasaki engines.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Page 4 of 4 1 2 3 4
