M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
67 registered members (Anduril, bbhero, ammolab, benjy, 10 invisible), 1,483 guests, and 62 spiders.
Topics286,168
Posts4,903,489
Members67,572
Most Online2,967
Mar 10th, 2019
DD SL1 led headlights #5030902
03/04/19 02:28 AM
03/04/19 02:28 AM
Chicagoland
Skippy722 Online content OP
Skippy722  Online Content OP
Chicagoland
My 2016 300S came from the factory with 9005 projector headlights. I immediately upgraded them to 9011 HIR1 bulbs and ran those for 11 months. I was never a fan of the halogen yellow color, and I know you can’t just go swapping any old led or even hid in there and expecting miracles.
Well, enter the Diode Dynamics SL1. They promised factory beam pattern with a decent upgrade over stock in light output. Being a Mopar, antiflicker modules were a no brainer. Everything fit within the headlight assembly with the factory dust covers, no drilling holes or running wiring harnesses required.
Came in Wednesday and immediately installed them, then left for work. Coming home I was rather disappointed, they weren’t as good as I was hoping... fast forward to Sunday night I decided I’d try clocking the bulbs. The factory bulbs are in there at a 4-10 or 5-11 position, okay for a halogen bulb but not so much for an led. Got them so the chips fired out at a 9-3 position and took it for a drive.
WOW! Huge improvement! Identical beam pattern to the 9011’s, lighting on the road is identical to the 9011’s, and IMO much better color. And no glare!
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: DD SL1 led headlights [Re: Skippy722] #5042153
03/13/19 10:44 PM
03/13/19 10:44 PM
Texas
PumpPusher Offline
PumpPusher  Offline
Texas
Nice. I want to do mine, but the whole having to clock them scares me off. I'd have to disassemble the front end to make adjustments.
Re: DD SL1 led headlights [Re: PumpPusher] #5042237
03/14/19 01:41 AM
03/14/19 01:41 AM
Chicagoland
Chicagoland
If I was smart, I would have compared them and clocked them the first time. But because Chrysler, we can’t just be normal and put the bulbs in the right way lol. First car I’ve ever come across where the connector wasn’t straight up and down when the bulb was seated.
Re: DD SL1 led headlights [Re: Skippy722] #5042707
03/14/19 11:43 AM
03/14/19 11:43 AM
Southeast
meep Offline
meep  Offline
Southeast
Measuring the change in light pattern with a ruler on my monitor, the top of the beam at the hotspot has moved from 5/16" to 10/16" off the ground. This is a significant change in cutoff at the hotspot.
Measuring at about 4' in from the edge of the wall at the left, where traffic is approaching, the cutoff has changed from 11/32" to 19/32"
Chances are, an approaching sedan is now being glared, and your beam is a little hot in someones rearview. The beam height has doubled from the ground, and may be over horizontal. To make this work, you need to lower the aim to get the light back on the ground. Hopefully that looks even better.
Write back after you do that - we'd probably like to know since the LEDs have a lot of potential going for them - better than HID drop-ins.... When you lower the beam, does the lighting remain smooth from close to far? or does the ground 30' from you become too bright while the horizon doesn't keep up? I'd really like to, and I'll bet most viewers here, would like to know.
it kinda goes like this--
1. is output good?
2. is the cutoff out of everyone's eyes?
3. is the foreground/distance distribution correct?
I've yet to find a drop-in that gets #3.
Thank you for putting out a well-thought and photographed post.
-m
2018 F150
2015 crv (wifey!)
Re: DD SL1 led headlights [Re: meep] #5042917
03/14/19 02:05 PM
03/14/19 02:05 PM
Chicagoland
Chicagoland
1. is output good?
-m
Both pictures are of the LED’s, the top one is low beam while the bottom is high beam.
I feel as though the beam pattern is identical to the halogens, while being just a tad bit brighter but it has a color I’m more comfortable with.
Re: DD SL1 led headlights [Re: Skippy722] #5043474
03/15/19 04:32 AM
03/15/19 04:32 AM
Chicagoland
Chicagoland
First, something I should have added into my first post. All headlights are different, so you will get different performance out of different ones. The headlights on my 300 were always very narrow, even with the halogens. The LED’s DID NOT make the beam pattern any wider or narrower.
Low beam on the top. High beam on the bottom. Phone held on top of the steering wheel.
Pictures taken quickly with a phone, didn’t want a car to come up and wonder why I’m sitting at an otherwise deserted 4 way stop flicking my lights around at 4am!
The high beam picture is a more accurate representation of foreground light, it’s about the same whether in low or high. The low beam shot is a bit overexposed.
Re: DD SL1 led headlights [Re: Skippy722] #5043549
03/15/19 07:15 AM
03/15/19 07:15 AM
Southeast
meep Offline
meep  Offline
Southeast
I gotta admit. that's pretty good. the stock housings really seem to hold it together well. to me the foreground seems a little hot but the distance beam is /impressive/ in the photo and it's really hard to know for certain with a camera... LED. Either way, it's far better than either of my vehicles, and the low beam cutoff does seem very sharp, which is definitely something you want. I naturally expect most HL mods to be worse than oem, but this one is one of the best I've seen.
2018 F150
2015 crv (wifey!)
Re: DD SL1 led headlights [Re: Skippy722] #5044022
03/15/19 03:58 PM
03/15/19 03:58 PM
Chicagoland
Chicagoland
Thank you meep! I will eventually do a proper HID projector retrofit, but that’s going to a few years down the road still.
