For users of Liqui Moly, I am interested in getting your input on the product. I saw YT video posted by Bill Trammell on MACTFOREDGE and MACTGARAGE giving his analysis of the product based on spec sheet, SDS and VOA, and comparing to a Wal-Mart Supertech product. He immediately calls it a scam because the products does not contain Moly, and says it is marketing deception. He then uses a bogus SDS, it was the UK/EU document for the wrong product and API grade, and points to possible mixture of oils claiming this is the full base oil formulation. He does not use the correct OSHA SDS, even though he is certified OSHA trainer and auditor. One look at the SDS, it clearly shows this petroleum description makes up less than 10% of the product, but he does not show his viewers that, and ignores the severely hydrotreated oil making up 60-80%. He used the spec sheet, latest and greatest from the company, not the spec sheet of the actual oil (SN only) he used and tested. He claims the TBN is wrong and the company is misrepresenting their product. The test is from Blackstone, and the D4739 test typically reports lower values on average. He claims at the end of the video is only good for 3-5k miles, despite what the manufacture reports, and said it is a Group 1 oil and unknown amount of Group II. He had not completed any actual real world testing or UOA, and compares it to another VOA. When I offered him the correct SDS and spec sheet he refused, and said he does not have time or money to verify the information. He openly challenges Liqui Moly to contact him, but he is unwilling to give out his contact info. He collect ad revenue from YT but he blocks commenting on his videos because there are too many crazy's out there, and the only commenting is through private FB group. If interested, join the group and ask questions and see what kind of response you get. Below is the link
Liqui Moly vs Supertech 5W20 is there a deception[/url]https://youtu.be/MCBJ-FnKxN4
