M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
94 registered members (bbhero, ammolab, Alfred_B, Aero540T, agpatel, 11 invisible), 1,677 guests, and 57 spiders.
Topics286,168
Posts4,903,464
Members67,572
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Grease for car door lock barrel? [Re: Spetz] #5041524
03/13/19 11:33 AM
03/13/19 11:33 AM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
I've been using a LITTLE BIT of fluid film in the locks for my 2011 F150 for the past few years. Seems to work well, they haven't iced up or frozen since i started this (not even teh tailgate which was very bad at freezing before). Ford could take some of this advice on their newer F150's though smirk2
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Grease for car door lock barrel? [Re: Spetz] #5041785
03/13/19 03:38 PM
03/13/19 03:38 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I have a quart of Slick 50 on my shelf that would be good or this application. Like Tri-Flow, it has teflon particles in an oil base, but isn't as horribly expensive as Tri-Flow.
Re: Grease for car door lock barrel? [Re: Kestas] #5042801
03/14/19 12:49 PM
03/14/19 12:49 PM
California
nthach Offline
nthach  Offline
California
Originally Posted by Kestas
Don't get too crazy with the graphite lube. I've read reports where repeated use results in a mass of graphite caked in the mechanism. I suggest cleaning the tumbler with a solvent (WD-40, alcohol) before relubing.
I've been using Lock-Ease all this time with no issues. I'll start using WD-40 dry lube instead.
Which reminds me, I need to relube and work a key into all my locks.
Re: Grease for car door lock barrel? [Re: spasm3] #5042809
03/14/19 12:52 PM
03/14/19 12:52 PM
California
nthach Offline
nthach  Offline
California
Originally Posted by spasm3
I like super lube dry film lubricant, its in a spray can with a red zip tube.
GM is a fan of their grease for lubing ignition cylinders I will add.
Re: Grease for car door lock barrel? [Re: nthach] #5043029
03/14/19 03:38 PM
03/14/19 03:38 PM
Kansas
jacobs Offline
jacobs  Offline
Kansas
About 25 years ago I took a door lock to a locksmith because it was so corroded the key wouldn't turn in it. The locksmith disassembled it, cleaned it up, then packed it with grease and it's been trouble free ever since. He said the heavy grease will keep out the water.
Re: Grease for car door lock barrel? [Re: Spetz] #5043031
03/14/19 03:41 PM
03/14/19 03:41 PM
Oshawa, Ontario Canada
JC1 Online content
JC1  Online Content
My Sienna locks had siezed.cleaned it brake cleaner and used white lithium grease to lube it.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Page 2 of 2 1 2
