Bent Jack Stand Ratchet Bar
by The Critic - 05/28/20 01:44 AM
They're burning the city down
by 14Accent - 05/28/20 12:33 AM
Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
BlackMagicVarian, Mustache, mountaingoat, Alegrianyc, unavailable
71545 Registered Users
25 registered members (Bscott07, Bjornviken, blufeb95, BlakeB, bbhero, Ag76, 1 invisible), 1,107 guests, and 24 spiders.
Topics305,958
Posts5,283,648
Members71,545
Page 1 of 3 1 2 3
Change oil and / or filter in brand new vehicle? #5042725 03/14/19 12:01 PM
E
Ed_Flecko Offline OP
E
I'm in the process of buying a new GMC Canyon, with the 3.6 Liter V-6 LGZ Engine (https://bit.ly/2u4UXUz). Just like everyone, I'm sure, I want to break-in the motor the most efficiently as possible.
While I don't think it's necessary to dump brand new oil, I am very tempted to immediately change oil filters from the factory ACDelco Professional PF2257G ("Equipped with 98% multi-pass filtering efficiency at 25-30 microns for excellent filtering capabilities" - https://bit.ly/2UB1WQP) to either a Fram Tough Guard ("Stronger, more durable media provides an outstanding 99% dirt-trapping efficiency - FRAM Group testing of average filter efficiency of PH8A, 3387A and 4967 or equivalent FRAM TG or XG models under ISO 4548-12 for particles greater than 20 microns.") or Fram Ultra.
Since a brand new motor is most likely to have tiny metal shaving or other unwanted stuff floating in the oil, I personally think this might be a smart thing to do. However, do YOU think immediately changing oil filters is a...
  • Good idea
  • Bad idea
  • Meh...why bother. Change the filter at the first oil change
Thank you,
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042728 03/14/19 12:03 PM
B
Bottom_Feeder Offline
B
Anything floating around in a new engine is going to be large enough to be caught by even a mediocre oil filter, in my opinion.
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042736 03/14/19 12:12 PM
Yah-Tah-Hey Offline
Drive it.
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042747 03/14/19 12:22 PM
B
BMWTurboDzl Offline
B
popcorn
435i
Re: Change oil and / or filter in brand new vehicle? [Re: BMWTurboDzl] #5042753 03/14/19 12:26 PM
Malo83 Offline
I always dump the factory fill between 500/1K miles, don't want a bunch of grit floating around my new engine. cheers
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042756 03/14/19 12:28 PM
L
Loi Offline
L
Best way to break in an engine to ensure piston rings seat is to drive it with varying RPM. Avoid highway cruising as much as possible. You can change the oil at 1000mi if that makes you feel more comfortable or follow the manufacturer's recommended oil change interval.
'05 GDB STI
'16 VAB STI
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042767 03/14/19 12:32 PM
A
anndel Offline
A
I all of our and customer's vehicles, I change the factory filled oil and filter at about 1,000 miles and consider that break-in. I replace with any of the fine synthetic oils - Mobil 1, Pennzoil, Valvoline, Castrol plus either Fram Ultra or OEM filter unless the customer requests Amsoil.
Any yes, in several occasions I've cut open the filter and found metal bits caught in the filter element.
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - Amsoil SS 10W-30, Amsoil FIlter
2005 Toyota Avalon XL, 3.5L V6, Amsoil SS 5W-30, Amsoil Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS 5W-30, Yota OEM Filter
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042784 03/14/19 12:40 PM
StevieC Offline
I've always changed out early and multiple times in the first 5,000. Oil is cheap, engines aren't and there is a lot of swarf floating around the engine when it's new before it settles down with regular oil changes.
Anything you do will help it along won't hurt and could be beneficial, but the OE will tell you it's not necessary.
I would also add that given the GM timing chain issues, if it were mine I would be changing it out at least within the first 600 miles and then keep a short OCI thereafter for the first bit until I felt like everything that could be flushed out has been. I'd also use the spec'ed oil and weight but would make sure it had moly in its additive package. (Preference)
Some might say it's a waste of oil but how much cheaper is the oil than changing out the chain and the headache of having to go through it. wink
'18 Caravan - 50k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Change oil and / or filter in brand new vehicle? [Re: StevieC] #5042814 03/14/19 12:54 PM
E
E
I agree!
Currently, I use Castrol EDGE in both of our cars (5W-30) and truck (0W-40). I don't know if it has any "moly" but I've heard it does have a good additive package.
Ed
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042843 03/14/19 01:15 PM
newtoncd8 Offline
I understand you are talking about only changing the filter and not the oil. Meh, why bother.
12 Jeep GC, 04 Lexus RX330, 77 MG-B
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042848 03/14/19 01:18 PM
StevieC Offline
Originally Posted by Ed_Flecko
I agree!
Ed
Ed, I'm not sure and it depends on the which Edge you are using... There is a couple of them.
Re: Change oil and / or filter in brand new vehicle? [Re: StevieC] #5042876 03/14/19 01:38 PM
E
E
I agree!
Ed
I use "Castrol EDGE with Fluid TITANIUM Technology" - https://bit.ly/2W1Uajc
smile
Ed
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042889 03/14/19 01:47 PM
StevieC Offline
Yes it has Moly in it and it looks like it might be the better type Tri-Nuclear because of the ppm is lists: http://www.pqiadata.org/CastrolEdge5W20dexos1.html
(Could only find the 5w20 but it's usually the same across the weights when it's the same product)
Re: Change oil and / or filter in brand new vehicle? [Re: StevieC] #5042894 03/14/19 01:50 PM
E
E
Thank you!...I appreciate the detailed explanation!
smile
Ed
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042904 03/14/19 01:59 PM
StevieC Offline
Happy motoring and good luck with your new ride. thumbsup
Page 1 of 3 1 2 3
