Is my transmission fluid overfilled? Scion xB '10
by puredata - 08/22/19 02:38 AM
Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
oilq, Nesss, Robto, Chaparro_trucker, KiwiBiker
69027 Registered Users
15 registered members (Bailes1992, 4WD, iontrap, bonjo, dieselguy67, CATERHAM), 640 guests, and 22 spiders.
Topics293,636
Posts5,043,861
Members69,027
Most Online3,532
Jul 30th, 2019
Page 2 of 3 1 2 3
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042910 03/14/19 02:00 PM
P
PPWarrior Offline
P
Save your money, but a Tacoma
Re: Change oil and / or filter in brand new vehicle? [Re: PPWarrior] #5042922 03/14/19 02:09 PM
E
Ed_Flecko Offline OP
E
I thought about it, however they're overpriced, the V6 only puts out 278 hp, and I think they're butt ugly.
Oh, did I mention, I'm dumping my 2004 Tacoma?
smile
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042958 03/14/19 02:38 PM
Danno Offline
I put 400 3.0L diesel Sprinters into service and they all went 12,000 to 15,000 miles before their first oil change.
Did not lose any engines to oil failure up to 200,000 miles. Which is the last data point I have.
Lost 2 engines to hydro-locking when the trucks rolled in high winds.
and,FWIW
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042974 03/14/19 02:50 PM
dave1251 Offline
I do not change the oil early anymore on my new vehicles. I might change it a couple hundred miles early but IMO its nothing to worry about with modern machining and manufacturing.
don't use.
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5042976 03/14/19 02:51 PM
Mr Nice Offline
3-4K miles for my new cars.
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5043071 03/14/19 04:58 PM
4
46Harry Offline
4
I always change the oil and filter on a new or rebuilt engine around 1000 miles. It may not be necessary, but I've seen the trash in oil from from enough fresh engines that leads me to believe that it is a good idea.
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5043073 03/14/19 05:01 PM
O
oil_film_movies Offline
O
Get a magnetic drain plug. GoldPlug.com or drainplugmagnets.com are strong magnets. Others are often too weak.
Then see how much iron fuzz they capture.
I wouldn't touch the oil filter, but change the oil (leave filter on) at 1,000 miles to get the initial machining asperities cleaned out.
Re: Change oil and / or filter in brand new vehicle? [Re: Mr Nice] #5043093 03/14/19 05:20 PM
T
Triple_Se7en Offline
T
Me too! .... even with my new Santa Fe 2.4 GDI.
I've purchased a dozen new vehicles since 1970 and never had any kind of engine oil problem. The last eight new vehicles - we were first and last owner of them.
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5043102 03/14/19 05:29 PM
A
ARCOgraphite Offline
A
Ed - that's a base down canister. I would run maybe 7-10 hours then change the filter. Then change the oil and filter again at around 2K.
I don't know if you ll be able to see or get to junk/chips/flash accumulated down in the base.
Have you changed filters this decade on a canister system on any car/truck?
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5043103 03/14/19 05:30 PM
4WD Online Confused
Online Confused
I do 1k to 2k … and then OLM after that while under warranty
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5043114 03/14/19 05:43 PM
U
userfriendly Offline
U
You get 4 free oil changes in the first 2 years. You could do one now, and a couple in between the dealer ones.
I changed the oil and filter at 650 kms on my 2018 6.6L duramax. The dealer did the next one at 10,000. (6,200 miles).
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5043120 03/14/19 05:59 PM
147_Grain Offline
Change the oil and filter early.
Stick with the OEM oil filters for the first couple of years to avoid issues when the dealer changes your oil.
2019 Subaru Crosstreck
2013 Subaru Outback 3.6
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5043147 03/14/19 06:36 PM
O
oilpsi2high Offline
O
I'd change it early, but not before the break-in period.
I did my Cobalt SS after 2500 miles or so.
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5043164 03/14/19 06:52 PM
O
O
https://www.caranddriver.com/news/a26077592/gm-free-maintenance-reduced/
For 2019, I think this GMC only gets one free oil change, within 1 year of purchase.
Is it different in Canada?
My '18 Chevrolet in the U.S.A. (seems like Dinah Shore sang that.... https://www.youtube.com/watch?v=qhR8GZ_WWMM )
gets 2 free oil changes within 2 years.
Re: Change oil and / or filter in brand new vehicle? [Re: Ed_Flecko] #5043222 03/14/19 07:36 PM
Bud Offline
Not necessary.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Page 2 of 3 1 2 3
