Alright, I understand it's hard to explain via web but do you guys have any prefer method for mounting car tires?
I have mounted motorcycle ones in the past, removal and bead breaker doesn't seem too bad.
But for installation, I am unable to slide the rim on the tire, usually once wheel is pushed into the tire then other side is a matter of tire irons, patience and technique.
Not sure if I am doing something wrong and unable to slide the rim on to the tire? Appreciate any help and advise
P.S: if I go for HF manual tire changer, I have to means to fix that either in the floor or some plywood, hence not really pulling the trigger on it.
