Blue Devil Flush VS Prestone Flush & Cleaner
by BlueOvalFitter. 05/22/19 03:29 PM
Bro Truck Rant
by LoneRanger. 05/22/19 02:35 PM
The new mistress
by Dyusik. 05/22/19 01:16 PM
Water filter pitcher?
by Quattro Pete. 05/22/19 12:54 PM
Water heater on a timer?
by racin4ds. 05/22/19 12:08 PM
dealer short me half quart
by MetalSlug. 05/22/19 11:54 AM
Continuous pilot furnace and AC
by Brybo86. 05/22/19 11:41 AM
men can get breast cancer AMHIK
by andyd. 05/22/19 11:29 AM
Remove baseboard moulding for floor planking?
by JLawrence08648. 05/22/19 11:06 AM
coolant system burp process - blower fan off?
by NissanMaxima. 05/22/19 11:03 AM
Which 5w30 for gen lll Coyote 5.0?
by Toy4x4. 05/22/19 11:01 AM
Rotella T6 for Duramax LML. What flavour?
by weebl. 05/22/19 10:27 AM
Looking for IP rated 24V DC regulator/conditione
r
by DriveHard. 05/22/19 10:26 AM
Sealant Suggestion
by Lubener. 05/22/19 10:13 AM
Ronin 15% discount code
by 1978elcamino. 05/22/19 09:54 AM
Hydro Gear G730 trans shudder
by Fastzntn. 05/22/19 09:22 AM
Fire season starts early
by Snagglefoot. 05/22/19 09:12 AM
52Voodoo, HondaHrX, DirkDiggler87, Fordpuppy, Geowebby
68175 Registered Users
109 registered members (28oz, 2019StingrayZ51, 53' Stude, 1978elcamino, 08z06, 12 invisible), 2,194 guests, and 28 spiders.
Topics289,249
Posts4,965,393
Members68,175
Most Online2,967
Mar 10th, 2019
Ford 4000 oil specs #1977278
08/05/10 08:48 PM
08/05/10 08:48 PM
MS
Ben99GT Offline OP
Ben99GT  Offline OP
MS
Specifically oil specs for the power steering gear housing and power steering reservoir.
According to the specs the power steering gear housing calls for ESEN-M2C94-BA, ESW-M2C28-BA or M-4864-B and the power steering reservoir calls for ESEN-M2C92-A or M2C41.
From what I have been able to find ESEN-M2C92-A (power steering reservoir) is a 10W-30 hydraulic fluid and I think I have found a few sources for fluids that meet that spec, including Pennzoil. Any additional info. on this spec would be helpful.
The bigger problem is power steering gear housing (ESEN-MC28-BA), I haven't been able to find a fluid that meets that spec or what sort of properties this oil is. I think it might be a 90 weight gear oil, but I'm not sure.
Any help would be appreciated.
Edit: I meant to post this in the hydraulic fluid board.
2001 F150 Supercrew 4.6 - 321,000 miles- PP 5W-20/MC FL-820S
2011 Shelby GT500 SVTPP - 705 RWHP - PP Euro 0W-40/Wix 51372XP
Re: Ford 4000 oil specs [Re: Ben99GT] #1977379
08/05/10 10:33 PM
08/05/10 10:33 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
Don't know for sure, but give RedLine a call.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Ford 4000 oil specs [Re: JimPghPA] #1977537
08/06/10 06:32 AM
08/06/10 06:32 AM
Northern, NY
Rob_Roy Offline
Rob_Roy  Offline
Northern, NY
The following is from Shell Lubematch:
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: Ford 4000 oil specs [Re: Rob_Roy] #1977699
08/06/10 10:05 AM
08/06/10 10:05 AM
East of IGO
Steve S Offline
Steve S  Offline
East of IGO
The Ford 4000 is a tractor? Have you tried an oil jobber to find a match.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
Re: Ford 4000 oil specs [Re: Ben99GT] #1977874
08/06/10 01:08 PM
08/06/10 01:08 PM
NW Ohio
Jim Allen Offline
Jim Allen  Offline
NW Ohio
I have a similar tractor ('89 Ford 2810) and have used Rotella 10W30 engine oil, ISO 46 and 68 hydraulic fluid and the New Holland "134" (what the NH guys call it and what they will recommend you use) New Holland 134 and a generic 10W20 THF (trans hydraulic fluid) from Tractor Supply. They all worked equally well for the most part. I think if you look up any of the UTF (THFs) you will find they meet the specs you listed
I have rebuilt my steering system (which is almost the same as an older 4000) and it's really nothing special. Crude, actually. If you live in a hot climate, tend towards the heavier stuff, especially if you have a loader. My tractor has a loader on it, which puts a big strain on the front end and steering. Until I rebuilt the unit, the lighter grades tended to seep past the seals more.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
Re: Ford 4000 oil specs [Re: Jim Allen] #1977989
08/06/10 03:50 PM
08/06/10 03:50 PM
MS
Ben99GT Offline OP
Ben99GT  Offline OP
MS
Thanks, you have been a big help.
Re: Ford 4000 oil specs [Re: Ben99GT] #1978494
08/07/10 07:38 AM
08/07/10 07:38 AM
Bad Axe, MI
daman Offline
daman  Offline
Bad Axe, MI
If you want it simple that tractor can use any UTF that meets FORDs 134D spec,check the jug if it's listed you can use that in every sump but the engine.
"Always"....Mobil 1
Current fill: AFE 0w30
Re: Ford 4000 oil specs [Re: Ben99GT] #5038201
03/10/19 12:16 PM
03/10/19 12:16 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Ford M2c41-a is ATF A suffix A....
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
