Looking at the before and after printout, anyone saying that things should have been shimmed, cut and ground to get the specs closer to perfect is crazy. Just saying.
What I am trying to say is I highly doubt that the shop cheated you. I dont think everyone was high fiving each other on the great con job they just pulled off. More likely the tech seen an issue fixed it and its done. They were just doing their job.
FWIW its not hard to straighten a wheel in your driveway if you dont mind a little work. I would rather pay 80 bucks and get the full story though.
If it was the medical field and they did a check using a 100k machine, the charge would be 800 dollars just to hook it up.
Another reason I left the field of Automotive Technician.
