HF: Bauer Grinder Teardown/Analysis
by RayCJ. 07/21/19 05:55 AM
P21S Windshield Wash Booster
by Duffyjr. 07/21/19 05:25 AM
Transmission Swap
by Ponchinizo. 07/20/19 11:41 PM
Ecogard S4477
by Steiny. 07/20/19 11:25 PM
Manny Pacquiao vs Keith Thurman
by Warstud. 07/20/19 11:06 PM
Fuel Tanker Driver Here
by GoldDot40. 07/20/19 10:25 PM
Overfilled diff?
by HoosierJeeper. 07/20/19 10:02 PM
Brake Surge - Lexus
by MaximaGuy. 07/20/19 09:55 PM
Oil Rec for Street Driven & Track Usage
by randomhero439. 07/20/19 09:46 PM
Paint correction lighting setup for white paint
by Reddy45. 07/20/19 09:07 PM
Cannot pull credit report for wife
by Klutch9. 07/20/19 08:24 PM
Toyota 2AZ - FE!??
by miden851. 07/20/19 08:23 PM
What about the Chevy Trax?
by gregk24. 07/20/19 08:06 PM
Authentic 100% Synthetic 5W30/0W40 engine oil
by Denali376. 07/20/19 07:59 PM
Any Towing Reviews with New Tacoma V6 Manual 4x4?
by oilpsi2high. 07/20/19 07:39 PM
Synthetic 5W30 D1/Gen2 vs. Synthetic 10W30 ?
by ChrisD46. 07/20/19 07:00 PM
ECOGARD X4612 NEW FILTER CUT OPEN
by 53' Stude. 07/20/19 06:48 PM
Show me your dinner
by 53' Stude. 07/20/19 05:52 PM
grikor, Mikelima, mannydingo, Roadtripp, Denali376
68720 Registered Users
43 registered members (ccs368, atikovi, berniedd, 65convertible, AlienBug, bbhero, 4 invisible), 773 guests, and 19 spiders.
Topics292,178
Posts5,018,156
Members68,720
Most Online2,967
Mar 10th, 2019
Best cleaner for small engines #5037482
03/09/19 04:57 PM
03/09/19 04:57 PM
Alberta Canada
Festiva_Man Offline OP
Alberta Canada
I did not have much luck searching, but i am sure this has been discussed before. Could you guys give me your thoughts or direct me to a thread where this has already been discussed. I have a few lawn mowers, snow blowers, rototillers and so on that are older than me and could use some fuel cleaner. What would be the best product to use? Thanks.
1993 Ford festiva 421,000km fun car/daily driver
2002 Honda Civic 265,000km boring car/family car
Re: Best cleaner for small engines [Re: Festiva_Man] #5037502
03/09/19 05:20 PM
03/09/19 05:20 PM
S. Ont. Canada
neil57 Offline
neil57  Offline
S. Ont. Canada
Seafoam, available at canadian tire and many other parts stores.
09 GMC 2500HD Duramax/Allison EFI live
2018 Chevy Cruz
11 Ford Escape
Be realistic,don't be fooled by delusions of adequacy
Re: Best cleaner for small engines [Re: Festiva_Man] #5037526
03/09/19 05:43 PM
03/09/19 05:43 PM
Nebraska
Duffyjr Online content
Duffyjr  Online Content
Nebraska
Try some Star Tron, seen it work first hand on my blower when it started stumbling under load. Couple of tank fulls is all it took, now I add a couple cap fulls every time I fill it up.
89 GMC Sierra VR1 10w30/1036 Gold
08 Lucerne CX Advanced 5w30/1040 Gold
02 DeVille VWB 5w30/CQ Blue
18 Toro Super Recycler T5 10w30
Re: Best cleaner for small engines [Re: Festiva_Man] #5037530
03/09/19 05:47 PM
03/09/19 05:47 PM
South Central PA (Fulton Co)
Delta Offline
Delta  Offline
Berrymans Chemtool. I've successfully used it on my snowblower that had slight carb troubles even after cleaning. 1/4 of a can in the tank and ran it for 20 minutes; smoothed right out and has been working great all season.
'17 VW GTI 2.0T - 6MT - 16K - Edge 0w40
'15 Camry SE - 2.5 - 23K - PP 0w20
'09 Tacoma TRD - 4.0 - 132K
Re: Best cleaner for small engines [Re: Festiva_Man] #5037531
03/09/19 05:47 PM
03/09/19 05:47 PM
beaver land EH?
Quest Offline
Quest  Offline
beaver land EH?
air-cooled, side valve engines shall always run a tad rich and have carbon deposits on the top of the piston (or combustion chamber) no matter how meticulous you try to keep it clean. Compounded with carburettor system, these "crude" engines will never run clean no matter how hard you tried.
Don't waste time on gas additives. Simply (a) run fresh gasoline very time, and (b) schedule to pull the head and scrape the carbon every 100~200hrs.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: Best cleaner for small engines [Re: Festiva_Man] #5037551
03/09/19 06:05 PM
03/09/19 06:05 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
The best cleaner is to take the carburetor off the engine and disassemble it. Spray it with carb cleaner and poke it with wires.
Re: Best cleaner for small engines [Re: Delta] #5037552
03/09/19 06:06 PM
03/09/19 06:06 PM
Alberta Canada
Alberta Canada
I was told to use this by someone else but cant seem to find it in canada and its super expensive to order online frown
Re: Best cleaner for small engines [Re: das_peikko] #5037553
03/09/19 06:07 PM
03/09/19 06:07 PM
Alberta Canada
Alberta Canada
I was hoping to avoid that smile never taken a carb apart before, i would probably put something back togeather wrong.
Re: Best cleaner for small engines [Re: Quest] #5037560
03/09/19 06:10 PM
03/09/19 06:10 PM
Alberta Canada
Alberta Canada
Q.
Its not really the carbon in the engine i was wanting to clean but the carbs. These have all sat for full seasons year after year with the carbs full of gas. I always use fresh premium gas when i am using them, but the lawn mowers and rototillers sit for 8-9 months and the snow blower sits unused for 6 months every year with gas in the carbs. That gumms them up a bit right?
Re: Best cleaner for small engines [Re: Duffyjr] #5037566
03/09/19 06:12 PM
03/09/19 06:12 PM
Alberta Canada
Alberta Canada
Thanks, found it online for $30/bottle. Ill see if i can find it locally
Re: Best cleaner for small engines [Re: Festiva_Man] #5037579
03/09/19 06:23 PM
03/09/19 06:23 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
You'd be surprised by how simple they are and how few parts they have. You'd also be surprised by how simple they work.
Re: Best cleaner for small engines [Re: das_peikko] #5037589
03/09/19 06:31 PM
03/09/19 06:31 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Q.
You might get 1/8th of that run time before main jet gets clogged. I've heard that even TCW-3 can help stabilize the fuel and also keep the carbon deposits to a minimum.
Main jet is usually a single fastener to remove the bowl, and then the jet screws into the bowl. Easy as pie, you dad didn't teach you how to do it because it was not an issue before they started irishing up our gasoline.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Best cleaner for small engines [Re: Delta] #5037627
03/09/19 07:05 PM
03/09/19 07:05 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
That's all I use in small engine carbs, varnish is the issue with most and nothing removes it better from my experience. The carbs on every one of my OPE has been treated a small dose every full tank and not issues in 13 years. No carb has been off the engine or adjusted in any way.
Re: Best cleaner for small engines [Re: Festiva_Man] #5037639
03/09/19 07:14 PM
03/09/19 07:14 PM
High Tax Illinois
oldhp Offline
oldhp  Offline
High Tax Illinois
I put 10-12 ozs of MMO in my 4gal gas can year round. When I put it away I give it a big gulp extra MMO in the mower gas tank and keep it full. Starts right up in the spring.
2018 RAM 1500 3.6/8 speed.
2019 Dodge Charger SXT 3.6/8 speed.
"When others cut you down, remember where they came from."
"I don't run...........I just wait."
Re: Best cleaner for small engines [Re: Festiva_Man] #5037691
03/09/19 07:56 PM
03/09/19 07:56 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Chem-Tool is mostly acetone and lacquer thinner. Paint store stuff.. Cut with regular gas ,so it wont melt any plastics. I took advantage of a BOGO at Autozone last yr. Good for cleaning out a clogged carb. on a curb find.. My mowers don't need it if I keep the tanks full with the carb run dry. Its the little 2 stroke carbs on the Mantis and the weed wackers. that need it in the fuel to prevent varnish.
Thick oil is better grin2
