Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1¢ at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
Should I run an AC Delco Ultraguard gold?
by JHZR2 - 11/17/19 01:13 PM
Ford Ecoboost 400 at Homestead Miami Speedway
by bdcardinal - 11/17/19 01:08 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
35 registered members (BusyLittleShop, Black_Thunder, c502cid, 2009Caraman, 89Rustang, 4 invisible), 830 guests, and 22 spiders.
Topics297,567
Posts5,118,176
Members69,899
Most Online3,589
Nov 2nd, 2019
Drilling into concrete #5036253 03/08/19 02:56 PM
B
buck91 Offline OP
B
Need to make some 5/8” holes in a concrete slab. I have a 5/8” masonry bit which will fit my 1/2” chuck on my hammer drill. What I am unsure of is whether concrete would benefit from a pilot hole or if that would negatively impact the finished hole or drilling process?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Drilling into concrete [Re: buck91] #5036266 03/08/19 03:04 PM
CELICA_XX Offline
I've never used a pilot hole, just from my experience drilling into cinder blocks.
15 Toyota Prius - M1 EP 0w20 SN+
06 Acura MDX - M1 EP HM 5w30 SN+
02 Toyota ECHO - Valv MaxLife Syn 5w30 SN
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - M1 EP HM 5w30 SN+
Re: Drilling into concrete [Re: buck91] #5036274 03/08/19 03:11 PM
B
BigCahuna Offline
B
I've drilled a million holes in concrete and the thing that causes the most grief, is hitting a bluestone or a piece of rebar.,,
Re: Drilling into concrete [Re: buck91] #5036280 03/08/19 03:18 PM
B
barryh Offline
B
As masonry drills can wander, I always use a pilot hole for accuracy and it drills easier particularly if your hammer drill is not overly powerful.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (MB oil 229.5 5W40)
Re: Drilling into concrete [Re: BigCahuna] #5036362 03/08/19 04:21 PM
H
HighbrowHillbill Offline
H
This.
05' Ram 5.9 Cummins
11' Infiniti QX56
Re: Drilling into concrete [Re: buck91] #5036376 03/08/19 04:33 PM
L
Leo99 Offline
L
Not all hammer drills are the same. I had a Craftsmen and I struggled to drill into my foundation to hang a TV. It died and I picked up a cheap HF hammer drill. That cheap HF hammer drill is way more powerful than the Craftsmen.
Although, and me an concrete drilling don't get along that well. Can't tell you how many times I've drilled the hole and need another 1/4 inch and it just won't go any deeper.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Drilling into concrete [Re: buck91] #5036565 03/08/19 06:57 PM
Dave9 Offline
If you need very accurate spacing you might start a very shallow hole with a smaller bit, then switch over to the desired size, but other than that no you don't need a pilot hole.
Re: Drilling into concrete [Re: buck91] #5036571 03/08/19 07:02 PM
6
65f100 Offline
6
You need a rotary hammer instead of a hammer drill.
Re: Drilling into concrete [Re: 65f100] #5036620 03/08/19 07:33 PM
E
ET16 Offline
E
What? My experience is the opposite.
Re: Drilling into concrete [Re: buck91] #5036766 03/08/19 10:00 PM
B
buck91 Offline OP
B
Well just finished. My 1/2in hammer drill worked great with a masonry bit. No pilot hole, just started slow and it didn't want to wander at all. Nice tight, clean bore that my anchors grabbed nicely.
2011 F150 4x4 5.0L
Re: Drilling into concrete [Re: buck91] #5036794 03/08/19 10:48 PM
H
H
New safe? coffee
05' Ram 5.9 Cummins
11' Infiniti QX56
Re: Drilling into concrete [Re: HighbrowHillbill] #5036820 03/08/19 11:24 PM
B
buck91 Offline OP
B
Nothing that exciting, just installed a floor anchor to lock my snowblower and genny down.
2011 F150 4x4 5.0L
