I was watching a video from some guys who own a rear end rebuild/set up shop, and believe it or not they said that they prefer conventional over synthetic gear fluids. Which I found to be surprising, but interesting. The guy opened up a diff, started rotating the gears and explained Synthetic flows a little too well and that as the ring gear goes through the fluid, it throws the oil off the gears...and that the Synthetic gets thrown off a little too easily...that the conventional tends to "stick to them" a little better. The fluid may not last as long but it adheres to quickly moving gears better. Found that kind of interesting. And they weren't selling any fluid, believe me, this was just an instructional video on open diffs vs limited slip. The guys were very informative...talked about different size tires and how the effect the spider gears, etc.
