Originally Posted by BMWTurboDzl
So are boxers typically over-square?
Over-square refers to bore being larger than the length of the stroke, i.e., a 4" bore and a 3" stroke (like Ford 302) is over-square. As a general rule, gas engines will either be square (bore & stroke are equal) or oversquare. Low-speed engines designed for torque are generally under-square because torque is a vector, and mostly driven by the length of the crank stroke. Cylinders can be smaller diameter for a given displacement, because slower engine speeds and long strokes provide a "long" time for cylinder filling, especially as most torque-biased engines are forced induction, which helps cylinder filling as well.
So yes, most boxers are over-square, but this is not significantly different than other gasoline engines in the same displacement class.
