Windshield Damage
by MolaKule - 02/28/20 10:16 PM
Too close to home..
by Mad_Hatter - 02/28/20 10:03 PM
Pennzoil Platinum Euro L 5W-30 VOA
by mosschops - 02/28/20 09:53 PM
2008 Can Am Rotax 650 on my ATV
by sloinker - 02/28/20 09:49 PM
Another what is this
by parshisa - 02/28/20 09:20 PM
PTU oil choice?
by mpgo4th - 02/28/20 09:16 PM
School me on Radon...
by dareo - 02/28/20 08:56 PM
How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
90 registered members (4WD, bbhero, AZjeff, A310, 69GTX, 9 invisible), 1,731 guests, and 17 spiders.
Topics302,062
Posts5,208,310
Members70,826
Page 1 of 3 1 2 3
Here it is, first Rotella Gas Truck 5W20 VOA #5035460 03/07/19 10:57 PM
SubieRubyRoo Offline OP
As promised...
De omnibus dubitandum.
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5035467 03/07/19 11:05 PM
CT8 Offline
Thank you. The adds look similar to all the other sn+ dexos 1 gen 2 oils
2015 F150 2.7
2018 F350 6.2
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5035555 03/08/19 02:26 AM
wemay Offline
Nice Moly, Boron numbers. Must agree with CT8.
19 VW Passat Wolfsburg TSI (VW Genuine 0W-20+OEM)
13 Hyundai Santa Fe Sport 2.0T (Shell RGT 5W-30+OEM)
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5035587 03/08/19 04:23 AM
Snagglefoot Online Content
Online Content
Thanks for taking a bullet for the team. Not cheap. smile
If you want the job done right......do it yourself.
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5035593 03/08/19 04:45 AM
dave123 Offline
Thanks for work
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5035630 03/08/19 06:20 AM
J
JAG Offline
J
Looks good. Thanks!
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5035727 03/08/19 08:13 AM
J
JustN89 Online Content
Online Content
J
Awesome! Thanks Subie!
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: JustN89] #5035730 03/08/19 08:16 AM
4WD Online Confused
Online Confused
What about the symbol behind mid six base number … ?
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5036009 03/08/19 12:04 PM
Somebody smarter than me did point out the lab did the UOA ASTM method as they do not perform the “new oil” ASTM test. There is some error in the actual difference between the two tests, but I am not personally aware of what the actual difference is. I think they mentioned it was about 1.5-2.0 numbers, but I can’t say that’s true with confidence.
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5176733 08/01/19 02:19 PM
A
ad244 Offline
A
Thank you!
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5177160 08/02/19 03:32 AM
B
buster Offline
B
Looks good. Thanks!
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5179439 08/05/19 08:34 AM
Marco620 Offline
I'm not a TBN nut but it sure isn't very high. The moly and boron look good. Thank you for sharing!!
15' Civic 1.8 i-vtec 311,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5181528 08/07/19 08:27 PM
I mentioned it in one of the RGT threads- TestOil (and nearly every other lab only perform the ASTM test for used oil), which reports a TBN number 1-2 full points lower than the virgin oil ASTM method. A UOA will give you a more accurate result to see how TBN holds up on this oil. I should have a UOA on RGT 0w20 by October since its running a 6k OCI in an ‘18 Forester.
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5183111 08/09/19 06:28 PM
K
kstanf150 Online Content
Online Content
K
My F250 has a belly full of RTG 5W-30 right now
Got a blackstone kit ready for about the same time
Re: Here it is, first Rotella Gas Truck 5W20 VOA [Re: SubieRubyRoo] #5185337 08/12/19 05:57 PM
Mr Nice Offline
What’s the benefit of using this oil verses a PCMO ?
Page 1 of 3 1 2 3
