Hi all, I bought a 2wd 78 C10 this last fall and as the weather gets warmer will start wrenching on it. It has sat for 10 years with a blown small block. Amongst the long list of things to do is trans fluid and read diff fluid. It has a Turbo 350 trans with a shift kit and a 12 bolt posi rear end. For the trans what would you use? I have been debating on one of the Dex 3/ Merc type trans fluids or maybe a Dex 6. Worried a Dex 6 might not be the greatest for the old Turbo 350. What say you? Also for the rearend a regular old 80w90 or something of a newer spec, maybe with a additive. I'm newer to the older stuff so I'm looking for some help. Thanks in advance.
