Just curious but how long of an OCI are you going to do with the Ultra and the EP 0w20 on your new truck?
ZeeOSix said:The base gaskets are close enough - should work fine. The gasket on the XG2 is just a bit wider (same ID, slightly larger OD), which gives more sealing area on the filter mount. Just make sure the mount is a bit larger in dia then the gasket OD.[/quote
Reckon you could pull the old gasket and hold it up to the flange to eyeball the relative position …
I used the slightly longer XG10575 on GM's and Ford's many times …
Only stopped over my new engines and the PRV setting
