Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 08/23/19 11:32 PM
Castrol 5W50
by Snagglefoot - 08/23/19 11:29 PM
Camry Broke Down
by Nick1994 - 08/23/19 10:51 PM
Pumpkin Beer
by Capt - 08/23/19 09:26 PM
Possible bad Iridium plug
by Eric Smith - 08/23/19 08:57 PM
Is the 5.7gm engine still made brand new?
by motor_oil_madman - 08/23/19 08:19 PM
Motomaster OEPlus MOPH/MOCH Filters
by gamefoo21 - 08/23/19 07:29 PM
Man's best friend!
by Mad_Hatter - 08/23/19 06:53 PM
2007 Ford Fusion Cam Pics
by tig1 - 08/23/19 05:31 PM
Cloning a Lexus key
by Nayov - 08/23/19 04:23 PM
2011 GMC Acadia Shock/Strut Replacement
by panthermike - 08/23/19 03:49 PM
Confusion on oil to use on BMW 328i 2010
by goldenjava - 08/23/19 03:21 PM
ProSelect 27356 cut open
by Sayjac - 08/23/19 03:04 PM
Electrolux - Dryer reliability warning.
by pezzy669 - 08/23/19 02:37 PM
Microfiber Towels for different applications?
by Quattro Pete - 08/23/19 01:53 PM
Coated vs. painted rotors
by atikovi - 08/23/19 01:13 PM
New spark plugs, occasional misfire
by avacado11 - 08/23/19 12:34 PM
Boogyman, GeoffPD, CabanaBanana, tblack, goldenjava
69048 Registered Users
26 registered members (Bailes1992, bdcardinal, 4WD, 14Accent, 2002 Maxima SE, ArrestMeRedZ, 4 invisible), 730 guests, and 19 spiders.
Topics293,713
Posts5,045,452
Members69,044
Most Online3,532
Jul 30th, 2019
How do I measure the laundry powder? #5032639 03/05/19 05:19 PM
V
Vern_in_IL Offline OP
V
Got a FL Samsung. requires HE detergent.
I use Tide powder HE with the fresh crystals.
I always use the "lowest bar" on the scoop, extra rinse setting works great on most loads except the socks.
The socks I got to use the rinse setting 3 times, and still not all the soap is out. I even use half of the lowest recommended powder. I use medium spin(socks are wool)
What is the solution?
Re: How do I measure the laundry powder? [Re: Vern_in_IL] #5032670 03/05/19 05:48 PM
G
Greggy_D Offline
G
Use less powder.
Greggy D.
Re: How do I measure the laundry powder? [Re: Vern_in_IL] #5032674 03/05/19 05:51 PM
9
901Memphis Offline
9
Might need to run a cycle with no detergent added to get excess out.
2012 Chevy Cruze LT 1.4T - 62k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: How do I measure the laundry powder? [Re: 901Memphis] #5032679 03/05/19 05:55 PM
dkryan Offline
This!
Then you might consider switching to a detergent pod suitable for HE front loaders.
It oftentimes help prevent using too much detergent.
2014 Nissan Altima 2.5 SL
Shell T/SUV 5w-30/Fram Ultra
2005 Toyota Highlander 3.3L
Pennzoil Ultra 5w-30/Fram Ultra filter
2019 Subaru Outback 2.5L Limited
Pennzoil Platinum 0w-20/Wix XP filter
Re: How do I measure the laundry powder? [Re: Vern_in_IL] #5032682 03/05/19 05:56 PM
skyactiv Offline
In my experience powered laundry detergents made by Procter & Gamble suck at dissolving.
That could be your problem, even if you cant see it.
I've used the following P&G powder detergents: Tide with bleach, Gain and Cheer.
The solution is to buy Surf Sparkling Ocean powered laundry detergent available at Walmart.
It works/smells better than Tide unless your a slob who stains your clothes.
https://www.walmart.com/ip/Surf-Sparkling-Ocean-Powder-Laundry-Detergent-52-oz/17248279
Me: 13' VW GTI 3 door 6 speed manual
2018 Elantra Sport 6 speed manual
Re: How do I measure the laundry powder? [Re: Vern_in_IL] #5032684 03/05/19 05:58 PM
E
Eddie Offline
E
I think you should hand wash your socks separately :-))
2014 CX5 Touring 2.5L :-)
Re: How do I measure the laundry powder? [Re: skyactiv] #5032720 03/05/19 06:42 PM
V
V
Hey I'll give that a shot, lol at those comments:
Quote
I HAVE LEARNED NEVER TO WAIT UNTIL THERE IS A SMALL AMOUNT IN THE BOX. IT IS LIKE NOT WAITING FOR A PRESCRIPTION TO RUN OUT BEFORE YOU REFILL IT.
Haha! People are passionate about this stuff.
Quote
Use less powder.
Exactly, but it is BS that the lowest measure line is way too much for a load of socks.(10 pairs) I always thought the HE detergents have "filler" added so when you use the amount needed for a load, you're getting essentially what you need. Small loads upto the lowest line...etc.
The lowest measure line should be for small loads, I guess they didn't "HE" the scoop!
Re: How do I measure the laundry powder? [Re: dkryan] #5032727 03/05/19 06:46 PM
L
Leo99 Offline
L
This!
Sometimes the pods don't dissolve properly. We've moved to liquid detergent. I don't use much unless something is really dirty.
Also, some machines might rinse with cold water. Water is really cold this time of year. Might need to bump up to a warm water rinse.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: How do I measure the laundry powder? [Re: Vern_in_IL] #5032793 03/05/19 07:39 PM
SubieRubyRoo Offline
Yes, if you have hard water it will make dissolving powders difficult. I have only used liquids (either bulk liquid or pods) and have never had an issue. Change your detergent and see if that helps.
Re: How do I measure the laundry powder? [Re: Vern_in_IL] #5032935 03/05/19 09:08 PM
A
Alfred_B Offline
A
10 wool pairs of socks is quite light. The machine will measure the water needed based on the weight of the laundry. So it will end up using very little water which translates to a high laundry detergent ratio.
Re: How do I measure the laundry powder? [Re: Vern_in_IL] #5032980 03/05/19 09:32 PM
N
NO2 Offline
N
Throw in an old towel or two along with your socks. Modern washers are not designed to run at 10% capacity. Use extra rinse, highest spin speed and liquid detergent.
Re: How do I measure the laundry powder? [Re: Vern_in_IL] #5033124 03/05/19 11:09 PM
Q
Quattro Pete Offline
Q
Is there a reason why you're using powder instead of liquid detergent?
Re: How do I measure the laundry powder? [Re: Vern_in_IL] #5033168 03/06/19 12:06 AM
Marco620 Online Content
Online Content
The maid just uses the Tide pods as my skin doesn't do well with powder soaps or bar soap like Zest or Lava.
15' Civic 1.8 i-vtec 262,000 mi Redline 5w20, BP Cvt fluid, Archoil9100
Tornado Chaser/Doberman Whisperer
Son of a Navy Corpsman.
Re: How do I measure the laundry powder? [Re: Vern_in_IL] #5033406 03/06/19 09:09 AM
StevieC Offline
Powder is not the best for H.E. washers because it can clump and clog areas of the washing machine. I saw this first hand when I would repair washing machines hooked up to soap dispensers for the chemical company I worked for.
I also don't like pods for that reason. I've found goo in the back end of the washing machines for friends/family and in dishwashers that use the same packaging.
Use a liquid, and despite what the brands tell you there is little difference between them so find the cheapest that works for you. (Less is more)
Sunlight and Gain seem to work the best with the least amount in my hard water area.
'18 Caravan - 40k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: How do I measure the laundry powder? [Re: Vern_in_IL] #5033612 03/06/19 12:21 PM
P
Patman Offline
Global Moderator
Global Moderator
P
I honestly didn't even think they sold laundry "powder" any more. I've been using liquid detergent for the past 20 some odd years now. I always use a little bit less than they say to use as well, I think too much detergent is bad for the washing machine (and your clothes don't need that much soap anyways)
2018 Corvette, 15k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 151k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,119k, GC 0w40 & Fram Ultra
