Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
PH10060 oversized?
by bullwinkle - 02/18/20 11:36 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
spbonus, mtnwzrd11, TnTA2, TimN3QE, musclecarscott
70742 Registered Users
112 registered members (2K2AcuraTL, 01VFR, 28oz, 928, 53' Stude, Alfred_B, 5 invisible), 2,296 guests, and 21 spiders.
Topics301,613
Posts5,199,111
Members70,742
Page 1 of 4 1 2 3 4
Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) #5031769 03/04/19 07:22 PM
A
AtomicNumber53 Offline OP
A
I'm so OCD....
https://docs.google.com/spreadsheets/d/16uHVIi8s561ordoEB3WTqDTbDsesqSI4J3FqfgydK3k/edit?usp=sharing
I was looking for a thicker 15W-40 for more "shearing-resistance". Was considering the Amsoil MCF because of the chart that shows it didn't shear, but I believe that UOAs around here prove that it does shear. And of relevant note, I found two different specs for the Amsoil MCF oil, so I put the worse ones in this chart... and it makes it seem more like a 5W-40 if you look close enough! Not even sure why there is a 5W-40 grade viscosity, tho.
Think I might try out the Redline 10W40, Maxima Extra 10W-40, & Castrol Power1 4T 10W-50, as they all seem like solid synthetic options and they're all actually MA2 rated!! Their Viscosity Indexes are certainly higher than the HDEO options, so they should be shearing in our shared sumps more than the HDEOS. The HDEO options are pretty solid themselves, tho. Makes me wonder if chasing a synthetic oil is really worth it? Unless it's actually a 15W-40 like the new T6!! whistle
Only thing I didn't really try to notate was pour points, since it's not really important to me. Sorry if you were interested in those specs!
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: AtomicNumber53] #5031782 03/04/19 07:37 PM
A
A
Just remembered there actually is a synthetic 15W-40 already besides the new Rotella T6 ---- Royal Purple Duralec. It's not MA rated, but most don't seem to care that much about it around here.
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: AtomicNumber53] #5031830 03/04/19 08:10 PM
sloinker Offline
Lot of motorcycle shared sump enthusiasts use the Red Line or Motul. I used Red Line on my Nightrod as the factory fill would shear to water in a few hundred miles. The Red Line went to the 2k OCI I set for myself.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: AtomicNumber53] #5031832 03/04/19 08:12 PM
B
benjy Offline
B
no matter what your looking for you can't go wrong with Redline's real synthetic lubricants, that is if the price is ok with you. you give few details of what your looking to run in what + the ambient temps that affect selections so don't expect specific recommendations
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: AtomicNumber53] #5031857 03/04/19 08:32 PM
carviewsonic Offline
Your spreadsheet is a good summary... another one to add would be Mobil 1 Racing 4T 10W-40. Many bikers use and like Rotella T-5 (semi synthetic) 15W-40, and Rotella T-6 (full synthetic) 15W-40 is available now. I will probably change to Rotella T-6 due to lower cost.
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: benjy] #5031893 03/04/19 08:56 PM
B
Bonz Offline
B
Mobil 1 10w40 Racing 4T had a stellar performance for 4,603 miles last summer in high temp/higher rpm use in my ZRX 1200. Modded to around 145-150 hp and 85 ft/lbs. I like the torque and roll into it often, mashing the oil between the gears. smile. Saw a number of 100 deg F days and fan came on in slow traffic as the temp gauge soared at high elevation. This oil flat out shifted as well as the day I put it in for the full OCI and had a TBN of 6.5 remaining. 11.98 cSt used vs 13.5 cSt new. One of the thinner 40 wt oils to start, but held up in about as tough a situation as it could.
Rotella T5 15w40 syn blend did really well also, stayed in grade at a cSt of 12.77 after 3,700 miles.
Mobil 1 15w50 was another good one. cSt of 13.32 after 4,090 miles.
Mystic JT8 15w50 cSt of 12.55 after 3200 miles, had lower flashpoint due to some fuel so suspect the cSt was just bit low from that.
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: AtomicNumber53] #5031934 03/04/19 09:40 PM
A
A
There are some that I considered, but just took off because they didn't meet certain specs I was shooting for....
I felt the Mobil 1 10w-40 4T started out too thin for me. And I think there was some spec that just showed the "old" T6 (in 5w-40) is too thin for ANY motorcycle. Might've been HTHS, but I can't remember now.
I didn't really want to consider the Rotella T5 because Shell has already done us the favor of advertising that the T4 and T6 meet JASO MA specs but do NOT say so on the T5. Therefore, I only have to assume that it does have some sort of friction modifiers which wouldn't be good for our wet clutches. Just an educated guess?? Otherwise, it really does look like a pretty decent choice.
As for the Mobil 1 15W-50, I feel like there's something unknown about this oil that spooks many, including myself. There are rumors that it has friction modifiers, which I was unable to confirm or deny... but it's enough to steer me away.
Don't think I ever considered the Mystic, tho. Might add that one to the list....
Some I might have left off just because one spec was incredibly inferior, like a flash point of 190 deg C, or its HTHS was below 4. The list was obviously geared toward my own desires, but figured others might enjoy it. smile In retrospect, I probly shouldn't have deleted the rows of oils I didn't prefer, just because someone else might have found the data useful. Oh well... smirk
EDIT: Added the Mystik JT-8 in 3 different viscosities. That's some good stuff there, Pawpaw!!
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: AtomicNumber53] #5031968 03/04/19 10:24 PM
K
KneeGrinder Offline
K
#1 Motul 300 V 15W50, This is hands down the most common used oil at the race track, many use it for weekend warrior canyon bikes also. For a shared sump motor there is no better oil.
08 Tribeca 90k PUP 5w30
06 Accord 137k PP 0w20
03 Acura CL-S 90k M1 AP 5W20
02 Acura TL-S 241k ST 5W30
02 Accord EX 155k PP 0W20
02 K3500 99k M 1 ESP 5w40
00 F350 139k M 1300 15w40
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: AtomicNumber53] #5031972 03/04/19 10:25 PM
L
Linctex Offline
L
Not very "educated".....
Friction Modifiers are ADDED to oils to help them play nicely with wet clutches - - - not the other way around.
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: KneeGrinder] #5032007 03/04/19 11:35 PM
A
A
Thanks!! Added it to the list, and it might be my #1 now, too!! It looks more like a 10W-50.
I had added the Motul 300V 4T 10W-40, but it looked as weak as the Mobil 1 4T... so I took both of them off.
The friction modifiers added in "Energy Conserving" xW-20 and xW-30 weight oils are NOT wet clutch friendly. Hence, the JASO MA certification.
The educated guess comes down to Shell having enough insight to claim that they meet or exceed the JASO MA requirements on the T4 and T6 oils, then why wouldn't they put it on the T5 bottle as well??
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: AtomicNumber53] #5032020 03/05/19 12:10 AM
A
A
Got me thinking.... Why don't I add the Allison C-4 spec to the HDEO oils?? That's just about as good as a JASO MA rating, no??
There's only a few on this list that don't specifically claim to "meet or exceed" either one of these certs for wet clutches.... the 2 passenger oils I had listed (Mobil 1 FS X2 and Castrol Edge) and 2 other oils I have listed under HDEOs, which really aren't such (Castrol GTX and Quaker State 4x4).
Wanted to be as inclusive as possible if it met my range of specs.... but if it doesn't claim to meet any of the wet clutch certs, maybe it really doesn't belong in a motorcycle at all?!? Hmm....
Maybe there really is something to these wet clutch certs, because the Mystik documents explicitly state that the 15W-40 meets the Allison C-4 specs... but the other two viscosities (10W-40 and 15W-50) do *not* meet that spec. Interesting?? I think so...
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: AtomicNumber53] #5032090 03/05/19 05:39 AM
A
alarmguy Offline
A
Nice work Atomic, thanks for posting.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: AtomicNumber53] #5032132 03/05/19 07:12 AM
K
krismoriah72 Offline
K
I will throw another popular hard to shear oil in. Valvoline VR1 20w50. In this forum i have seen the words "cant shear it with a samurai sword"
While you are making a list may as well throw in these oils Valvoline 4-Stroke Full Synthetic Motorcycle Oil, Shell Advance Ultra 4T
And just for fun Lucas 10w40 Synthetic motorcycle oil with Moly
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: AtomicNumber53] #5032193 03/05/19 08:26 AM
T
troop Offline
T
Another one .. Shell Advance 4T Ultra 15w-50. Great price at Walmart but sells out fast. I got a couple quarts yesterday.
https://www.walmart.com/ip/SHELL-ADVANCE-4T-ULTRA-15W-50-SYNTHETIC-MOTORCYCLE-OIL-1-Liter/900080455
https://www.shell.com/motorist/oils...-motorcycle-oil/shell-advance-ultra.html
Re: Detailed List of Motorcycle Oils (around 15W-40 or thicker characteristics) [Re: krismoriah72] #5032197 03/05/19 08:30 AM
A
A
I didn't realize how many motorcycle oils Lucas offers!! Only saw the 10W-50 Lucas in stores and took it off the list because it was more like a 20W-50 at startup, which is a bit too thick for my application... just like the Valvoline VR1. But it's strange that Lucas' own 20W-50 is thinner than their 10W-50. So weird.
I've added a couple of the Lucas oils, tho.... EXCEPT for the Lucas 10W-40 w/ Moly, because it's only rated JASO MB. They specifically market this oil for scooters! Another prime example of how most friction modifiers don't typically belong in shared sumps w/ wet clutches.
And now that I'm looking into it, I don't think the VR1 is JASO MA rated either. Their very own spec sheet says they use friction modifiers to improve performance (since it *is* a racing oil), so: "Valvoline VR1 Racing Motor Oil is not recommended for use in wet clutches (use Valvoline 4-Stroke Motorcycle Oil)."
I'd already added the synthetic option of the Valvoline 4-Stroke 10W-40... but thought that a KV100 of 14.1 was a little too low for a shared sump. Guess it's right there with the Amsoil MCF, tho....
Conventional options I haven't added yet (which would certainly be fine for shared sumps, if not better than the synthetics):
- Valvoline 4-Stroke 10W-40
- Lucas 10W-40
Page 1 of 4 1 2 3 4
