Hello everyone,
My car has just got off the warranty and I decided to do all the oil changes myself via fluid extractor.
The car is 2013 VW CC with 2.0 TSI engine and DSG trans. It has also been chip tuned with Unitronic Stage 1 ECU and Stage 1 TCU recently. All the oil changes been performed at 7-7.5K and it is driven energetically quite often.
My dealer used to put Castrol 5W30 or 5W40 Professional into it and the first DIY oil change I did with a cheap-o Castrol Edge 5W40 that I got at Costco. The engine burned like 400-500 ml of it in 6000 km. I switched to LIQUI MOLY 5W40 LEICHTLAUF for the second DIY oil change and so far I like it just as I liked Liqui Moly DSG fluid. It seems that the engine runs more smoothly but don't know on the burning rates yet.
However, I am also thinking about LM Molygen 5W40 or LM SynthOil 0W40 as better options potentially. Synthoil seems to be an older but 100% synthetic formula whereas Molygen has the latest additives. Leichlauf is still on the table.
Here is how my current broader selection for oils with all the options on the table looks like:
Castrol Edge 5W40 30-35CAD (the cheapest, oil changes can be done say every 5K?)
Mobil 1 0W40 30-50CAD (often discounts, some complaints on high burning)
FUCHS TITAN GT1 5W40 XTL technology 50CAD (may not be the best since designed with DPF filters in mind)
Liqui Moly 5W30 Long Time Hi-Tec 50-65CAD (same- DPF, low-SAPS, not that good for non-dpf turbo engines)
LIQUI MOLY 5W40 LEICHTLAUF HIGH TECH 55-65CAD (seems like a good cost/benefit balance, getting older/cheaper, oil changes at 7-8K. I may add CERATEC for healthy chain?)
LIQUI MOLY 0W40 SYNTH OIL 60CAD (100% synthetic but older and getting cheaper, hard to find)
LIQUI MOLY MOLYGEN NEW GENERATION 5W40 60-75 CAD (is the best? but the most expensive)
Thanks everyone for your thoughts!
