Originally Posted by 1JZ_E46
Originally Posted by tenderloin
Don't the new SN+ oils have less calcium that was contributing to valve deposits in DI engines...and have additional levels of magnesium? If that is the case then an oil can help change/control that....
Less calcium, yes, but not for the reason you mentioned.
HOW CAN LSPI PROBLEMS BE SOLVED?
Unfortunately there is not one root cause of LSPI, but research indicates that the lubricants used can play a role in combatting this issue. Calcium containing additives are strongly associated with LSPI, therefore a fundamental change in additive technology can mitigate LSPI. API SN Plus is only the first step in this battle with LSPI, with more formulary changes to be addressed with the upcoming ILSAC GF-6 category.
Total
How does API SN PLUS address LSPI?
A motor oil works thanks to an ingredient called the engine detergent, which keeps soot, dirt and other debris from interfering with the lubricant. Traditional motor oils use calcium and/or magnesium for this. However, research has shown that oils with a lower calcium and higher magnesium composition lead to fewer incidents of LSPI. Oils that meet API SN PLUS standards use more magnesium for the engine detergent, making them far less susceptible to LSPI.
Cenex
