Which way does transmission fluid flow when you flush? Fill tube to pan to torque converter to radiator? Or is it fill tube to converter to pan to radiator? Or is it ?????
I'm basically wondering if I drain the pan 1st, refil and then disconnect the return line from the radiator, is new fluid pushing out old? or is it mixing and pushing out new with the old?
Does my question(s) make any sense?
[ October 17, 2003, 10:43 PM: Message edited by: Roger ]
