Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Katdaddy, graphine, Bebo77, 2EHA, jonnyb433
70467 Registered Users
36 registered members (aquariuscsm, BlakeB, agpatel, 2013ecof150, 6 invisible), 1,312 guests, and 22 spiders.
Topics300,300
Posts5,172,788
Members70,467
Most Online3,728
Jan 11th, 2020
Can a "High Mileage" oil help reduce blowby? #5029602 03/02/19 08:20 PM
slickoil Offline OP
Can a "High Mileage" oil help reduce blowby? Vehicle is a 2010 Toyota Prius with ~146K, if that matters.
Re: Can a "High Mileage" oil help reduce blowby? [Re: slickoil] #5029610 03/02/19 08:28 PM
K
kstanf150 Offline
K
No
Re: Can a "High Mileage" oil help reduce blowby? [Re: slickoil] #5029623 03/02/19 08:39 PM
ekpolk Offline
Global Moderator
Global Moderator
Maybe, and only indirectly, not inherently because they're "high mileage" oils. Many of the HM oils have viscosities toward the higher end of the spec range for a particular grade, compared to their non-HM siblinigs. Vanilla M1 5w-30 is 11.0 cSt whereas the M1-HM flavor of 5w-30 is 12.1 cSt (hot of course). To the extent that the higher vis might reduce blow by, then again, maybe.
All that said, if blow by has become an issue, for whatever reason, your problems are probably greater than that which might be addressed by tinkering with oil selection.
18 Prius Two-Eco (L-Ion Batt), Mag Grey, 4000 miles (M1 AFE 0W-20).
07 Avalon XLS, Cassis Pearl, only 70k miles (M1 EP 5w-30).
04 Prius, Black, 200k miles (M1 EP 5w-30). 2006-2019 --RIP 😥
Re: Can a "High Mileage" oil help reduce blowby? [Re: slickoil] #5029639 03/02/19 08:56 PM
W
Warstud Offline
W
Not gonna help much but since your in SC you could just go with a thicker oil.
Re: Can a "High Mileage" oil help reduce blowby? [Re: ekpolk] #5029647 03/02/19 09:04 PM
K
kstanf150 Offline
K
High mileage oil is nothing more than good marketing
Re: Can a "High Mileage" oil help reduce blowby? [Re: slickoil] #5029673 03/02/19 09:49 PM
Q
Quest Offline
Q
what makes you think you have a blowby issue?
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: Can a "High Mileage" oil help reduce blowby? [Re: kstanf150] #5029680 03/02/19 10:01 PM
Y
y_p_w Offline
Y
Darn you to heck MaxLife!!!
Actually I remember when MaxLife and many of the copycat high mileage motor oils came out they didn't have the API EOLCS donut. They might have even fudged a bit where they couldn't meet the standard, but these days they formulate something that does.
Re: Can a "High Mileage" oil help reduce blowby? [Re: slickoil] #5029716 03/02/19 11:17 PM
das_peikko Offline
Blow-by has always been reduced with thick oil. Thick oil is harder to get past the piston rings and into the combustion chamber.
Re: Can a "High Mileage" oil help reduce blowby? [Re: slickoil] #5029808 03/03/19 04:19 AM
demarpaint Offline
Possibly.
God Bless Our Troops
Re: Can a "High Mileage" oil help reduce blowby? [Re: slickoil] #5029978 03/03/19 09:19 AM
J
joekingcorvette Offline
J
I have had high mileage vehicles but never thought I had the need to a high mileage oil. I doubt if it will help your problem.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Can a "High Mileage" oil help reduce blowby? [Re: slickoil] #5030020 03/03/19 10:10 AM
B
benjy Offline
B
HM oil worked for me! aunts 1999 jeep was leaking quite a bit but after 2 changes, 6 mo intervals its getting better. on a similar note girlfriends DI 2.5 LS malibu cut consumption in half with a euro spec 5-40 compared to a 10-30 + don't even mention the spec 20 than ran thru it when new. all oils fake group III synthetic.
Re: Can a "High Mileage" oil help reduce blowby? [Re: y_p_w] #5030098 03/03/19 11:03 AM
dave1251 Offline
Yeah most were thicker and had a bit more additives. QS Defy was one who had more ZDDP at API SL levels during the SN era.
don't use.
Re: Can a "High Mileage" oil help reduce blowby? [Re: benjy] #5030103 03/03/19 11:05 AM
dave1251 Offline
Once again what does it matter about "fake" group III synthetic do you live in the Artic and Pennsylvania is cold it's not the Artic.
don't use.
Re: Can a "High Mileage" oil help reduce blowby? [Re: Quest] #5030295 03/03/19 02:17 PM
slickoil Offline OP
The Toyota Prius is consuming about 1QT of oil every 750miles. This is a known issue with the 2010-2014 Toyota Prius. The fix recommended by Toyota (replacing the piston rings) costs over $1500, so that's not an affordable possibility unless Toyota pays for it (working on getting that to happen).
It hasn't been confirmed to be a blowby issue (not sure how to verify that for sure), but since there is a known issue with the Toyota Prius, and the symptoms match, it's the most likely culprit.
Re: Can a "High Mileage" oil help reduce blowby? [Re: Warstud] #5030311 03/03/19 02:30 PM
P
Patman Offline
Global Moderator
Global Moderator
P
I agree.
I think HM oils are a waste of shelf space. If someone has a higher mileage engine that's burning more oil than they are comfortable with, just move to a thicker viscosity.
2018 Corvette, 17k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 154k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,125k, GC 0w40 & Fram Ultra
