M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
90 registered members (AndyB, ammolab, Alfred_B, Aero540T, agpatel, 9 invisible), 1,683 guests, and 57 spiders.
Topics286,168
Posts4,903,464
Members67,572
Most Online2,967
Mar 10th, 2019
Amsoil Marine vs ATV vs Rotella T6 #4823631
07/26/18 02:01 PM
07/26/18 02:01 PM
Southern Middle Tennesee
Arctic388 Offline OP
studying up on oils for a Seadoo GTI 130/155 and have found these 3 options. my question is why would anyone use the Marine with a lower TBN and higher 4 ball wear test than the ATV specific Amsoil. plus the ATV is 0w40 instead of 10W40 and then you have Rotella T6 5w40 that is known to be a very good oil that will work for my situation and is a lot cheaper than Amsoil. and i am an Amsoil dealer. then to muddy the waters even more i read any 0-10w40 i.e. mobil1 or Pennzoil will work since i don't have the supercharger.
just want to get anyone opinion on here as to what they run and why.
2015 Sierra Z71
1999 Malibu
1996 Tahoe 4x4
2015 Seadoo GTI SE 155 Limited
2017 Seadoo GTI SE 130
1998 Yamaha XL760
1996 Seadoo GTX
2005 Yamaha Grizzly 660
https://www.youtube.com/user/Arctic388/videos
Re: Amsoil Marine vs ATV vs Rotella T6 [Re: Arctic388] #4823636
07/26/18 02:03 PM
07/26/18 02:03 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
15W-40 would be better that a 5W-40.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Amsoil Marine vs ATV vs Rotella T6 [Re: Arctic388] #4823680
07/26/18 03:08 PM
07/26/18 03:08 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
as you know, I'm new to SeaDoo, but I have been maintaining boats, snowmobiles, atv's for 30 years.
BRP's own oil is a 5w-40 semi-synth. for winter, they recommend full synth. (SkiDoo) I find it odd that they dont spec a full synth year round.
you also know that Amsoil has specifically created a marketed oils that are very specific to the exact use. this is largely a marketing effort. if you can create a demand for your product via fear, uncertainty, and doubt, the customer may be more likely to purchase your specific marine oil instead of a genreal purpose oil. I suspect there is very little difference between Amsoil's marine and utv oils. theoretically, your use is closer to marine: non dusty environment and liquid cooled. I doubt that TBN is a large concern - unless you run tons of hours on your unit.
I know that many rental outfits have 1000+ hours on their SeaDoo engines. I am curious what oils they used. I know from tons of marine experience, that many high-use boats use Rotella and/or Delo (basically HDEO oils) with great long-term results.
Personally, I will use Rotella or Amsoil Marine and not worry a bit.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Amsoil Marine vs ATV vs Rotella T6 [Re: CT8] #4823708
07/26/18 03:44 PM
07/26/18 03:44 PM
why you say 15 better than 5 ?
2015 Sierra Z71
1999 Malibu
1996 Tahoe 4x4
1998 Yamaha XL760
1996 Seadoo GTX
Re: Amsoil Marine vs ATV vs Rotella T6 [Re: Arctic388] #4823809
07/26/18 05:56 PM
07/26/18 05:56 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Less viscosity improver and a different bled of base oils "thicker"
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Amsoil Marine vs ATV vs Rotella T6 [Re: Arctic388] #4824560
07/27/18 04:14 PM
07/27/18 04:14 PM
dania bch, fl USA
rokwldr Offline
rokwldr  Offline
dania bch, fl USA
I have been using NAPA 15-40 Universal Fleet oil for 8 years in my F115 Yamaha. Never had a problem. Just two weels ago I walked away while flushing the motor and forgot to turn on the water. Came back to rubber smoke and an alarm. Melted the pump bad enough to ruin the upper gearcase seal. Repaired all that and it ran great. I changed the oil and no worries. I sent the oil to Blackstone with an explaination and it came back still useable. No Syn for me in my outboard cause I change it at 50 hrs anyway. That oil is made for NAPA by Valvoline.
Re: Amsoil Marine vs ATV vs Rotella T6 [Re: Arctic388] #4827947
07/31/18 07:02 PM
07/31/18 07:02 PM
New Jersey
Ursatdx Offline
Ursatdx  Offline
New Jersey
I run T6 in my 09 Yamaha 1.8L supercharged SHO.
Just turned 315 hrs on annual OCIs.
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Amsoil Marine vs ATV vs Rotella T6 [Re: Arctic388] #4838269
08/12/18 04:24 PM
08/12/18 04:24 PM
Waterloo, ON
Bluestream Offline
Bluestream  Offline
Waterloo, ON
The 130/155 is not supercharged so you can run pretty much what you want in it. I would go with a think 30W (GC) or a 40 weight as these engines work hard and run hot. I run Castrol 0W40 in my 155 RXP, and T6 5W40 in my GTR215 due to the wet clutch requirement
2000 VW Beetle 1.8T M5
2006 Pathfinder 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
Re: Amsoil Marine vs ATV vs Rotella T6 [Re: Arctic388] #5016324
02/19/19 11:55 AM
02/19/19 11:55 AM
Mississippi
MarshPirate Offline
MarshPirate  Offline
Mississippi
I use Rotella T6 in my 2 2015 Yamaha SHO's.
Re: Amsoil Marine vs ATV vs Rotella T6 [Re: Arctic388] #5018320
02/20/19 10:05 PM
02/20/19 10:05 PM
central Georgia
terminaldegree Offline
central Georgia
I would simply use whatever meets the spec and change it at a reasonable interval. Oil related engine failure isn't what's going to kill a modern, 4-stroke, naturally aspirated PWC such as yours.
If it's a brand new Sea Doo GTI, I would instead obsess over appearance care-- helped my parents buy a 2018 GTI Limited 155 to update their 2013 version of the exact same after it passed 200 hours and was going to need a little work (cracked gauge cover, worn seat upholstery). Boy, was that a mistake! Compared with the older machine, on the 2018, after just 30 hours: the factory cover is less durable, the quality of the upholstery got worse (thinner), the quality and durability of the gelcoat got worse, the stupid CM-Tec deck material is already showing spider cracks where no impact could have taken place, the floor mats were coming unglued from the deck, the 2018 machine is louder and heavier than the 2013 version, and the programming for the digital throttle in 'normal mode' is absurdly sluggish on the new machine.
'16 Mini Cooper S, 32k
'10 F150 4.6 3v, 120k
'13 Kawasaki STX-15f, 180 hr
'96 Sport Nautique 351 GT-40, 745 hr
Re: Amsoil Marine vs ATV vs Rotella T6 [Re: CT8] #5027277
03/01/19 06:40 AM
03/01/19 06:40 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
^^^That^^^
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
