Originally Posted by LeakySeals
Originally Posted by KalapanaBlack
195 and 205 are not the diameters, but the width of the tires.
65 is the aspect ratio, which is the sidewall size in relation to the width.
So a 205/65 is taller than a 195/65 because the 65 is basically the same percentage of a larger number.
As others have said, most likely the difference in size will play havoc with any electronic systems the car may have. If it doesn't have any reason to monitor wheel speed, you'd be fine to mix sizes. If the car is monitoring wheel speed for any of its systems, those systems will probably not work as intended. So this depends on the car.
If your state doesn't care about size or load index, mixing a 205/60R15 with your 195/65R15s will give you 4 effectively same-diameter tires and will mean the car won't care about the extra width, because you're adjusting out the difference in aspect ratio (i.e. diameter or height).
In PA, the car wouldn't pass state inspection with under size or under load tires. A standard load 205/65R15 will have a load index of 91 or 92 (extra load is 94).
Standard load 195/65R15 would probably be either 89 or 91 load index, but the smaller overall diameter/height would mean even if it's a 91, it would fail inspection for the underSIZE tires. If it's a 89 load rating, they would fail for underLOAD as well.
Best thing is, of course, 4 new correct-size tires, but if NH doesn't inspect tire size and/or load, the 205/60R15s will mix fine even with electronic systems on the car.
Thanks. The fresh bought Malibu classic has a current inspection sticker in New Hampshire so I guess they don't look at tire sizes. It's a 2005 so it has abs. It will only be for a month or two before I can get the back ones or what do you think about the condition of the tires I just posted? Can I get by with them for a couple of months till I can get all four? I will be out on the highway
They aren't great, but I would rate the possibility of driving on bad roads with malfunctioning/non-working ABS and/or traction control less operationally safe than living with some sidewall cracking for a few months. I would pay more attention to the shoulder of the tread and the grooves and sipes - are there radial cracks around the edge of the tread where it meets the sidewall? Are there any large cracks in the rain grooves and larger sipes? Those are the most problematic areas. The cracks in your picture just look to me like average 3-5 year old tires.
