WiFi “bridge” to outbuilding
by dlundblad - 08/20/19 05:00 AM
SynLube
by sloinker - 08/20/19 04:55 AM
Rental review : 2019 Dodge Charger
by FirstNissan - 08/20/19 12:14 AM
Truck diesel oil in Lawn mower (SAE30)
by Polyalphaolefin - 08/19/19 11:18 PM
Pinstripes Not Popular on Pickup Trucks?
by LoneRanger - 08/19/19 10:04 PM
More choices
by KeithS_NW_Ohio - 08/19/19 09:43 PM
INEOS to Surpass EXOM in PAO production.
by MolaKule - 08/19/19 09:17 PM
Need a miter saw
by JLawrence08648 - 08/19/19 09:01 PM
Using a 7.1 receiver with only 2 speakers
by Papa Bear - 08/19/19 08:44 PM
HD Sportster 5000 mi Red line PS 20w-50
by shanneba - 08/19/19 07:17 PM
College Football Time
by kstanf150 - 08/19/19 07:17 PM
Eco Plug oil drain plug
by passgas55 - 08/19/19 07:15 PM
Pep Boys Deals
by kstanf150 - 08/19/19 06:43 PM
MB229.5 and MB229.51
by Tikka - 08/19/19 06:35 PM
2019 Mazda 3 Recall....Wheels fall Off!
by Boomer - 08/19/19 05:43 PM
Rut Roh!😂
by Mad_Hatter - 08/19/19 04:40 PM
Oil for vintage Mopars
by 440Magnum - 08/19/19 04:37 PM
M1-102 vs M1-103
by Deontologist - 08/19/19 04:06 PM
Why no love for M1 gear oils?
by zuluplus30 - 08/19/19 03:02 PM
Brandon86, smartd_e, serhat, BlueSky, 444samc
69000 Registered Users
33 registered members (Bailes1992, 65convertible, 08z06, billt460, 53' Stude, 5 invisible), 637 guests, and 29 spiders.
Topics293,548
Posts5,042,123
Members69,000
Most Online3,532
Jul 30th, 2019
Page 1 of 3 1 2 3
2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi #5025448 02/27/19 01:04 PM
T
Terryd91 Offline OP
T
Well did my first UOA on my truck after what i thought would be enough breakin, so the high iron is hopefully just lingering breakin materials. My normal drive is terrible for the oil, 7 miles and 15 min of run time to work twice a day. Right now since it so cold in the mitten i have been using the remote start for a minute or two before I get ready to leave so that's not helping either. Also during the summer its primary job is to pull a 8500lb camper, about 2k of those miles on this change are towing.
I used Castrol EDGE Extended on this fill, honestly because it was the only thing on sale and i wanted to try something different due to a large amount of spark knock (on 93) and noise at the front of the engine. Dealer says its the HPFP but my stethoscope says otherwise. I'm interested to see how it pans out. Probably will change again next fill as i don't believe EDGE Extended is d1g2 and the 3.5l ecoboost can use all the help it can get with timing component wear. Might give the new marketing gimmick, i mean Rotella gas truck a try next time lol.
Blackstone has the oil listed wrong, oil was just PP not PUP.
[Linked Image]
2017 F150 3.5l Ecoboost.
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: Terryd91] #5025481 02/27/19 01:22 PM
A
addyguy Offline
A
At 15k, engine should be done break-in, I'd be disappointed in these results.
Name escapes me now, but the Castrol oil with 'intelligent clinging molecules' seems to work well here (startup? Magnatec?)
Seen some good results with it in these engines.
2010 Kia Soul 2U - 2.0L I-4, auto; 145k miles.
Castrol GTX HM 5W-30, STP blue bottle; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: Terryd91] #5025489 02/27/19 01:28 PM
PimTac Offline
The oil will have no effect on spark knock. That is something that should be looked into.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: addyguy] #5025511 02/27/19 01:42 PM
T
Terryd91 Offline OP
T
LSPI is what trying to rule out as its occuring at low rpm under load. Obviously not sever as it hasn't windowed the block or had any failures yet but it's disheartening to hear. PP should help prevent LSPI issues but you never know. The actual knock i hear at ide i believe is a VCT issue, but the dealer refuse to look at it because they claim its the tappet on the HPFP. Oddly my mileage goes up on fresh oil, last 3 changes. I think as the oil thins out from shearing and fuel dilution its leaking past the VCT actuators and tanking the engines efficiency taking the mileage with it. Looking at $400 and a weekend of tearing the valve covers off and see if that resolves it.
Yeah magnatech, I have that and some of the RGT on a price watch to snatch some up cheap.
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: Terryd91] #5025516 02/27/19 01:46 PM
Z
zorobabel Offline
Z
TBN looks spent.
What is the sump size?
1997 Maxima 206k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 205k, VWB 5W-20-30, MGL4967
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: Terryd91] #5025517 02/27/19 01:46 PM
doyall Offline
I'm thinking more like 3% - 4% fuel dilution.
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: doyall] #5025525 02/27/19 01:55 PM
T
Terryd91 Offline OP
T
Originally Posted by zorobabel
TBN looks spent.
Bit over 5qts, oil change is 6 with filter.
Probably. Oil smelled of gas and with my short trips and higher idle time it wasn't evaporating much out.
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: Terryd91] #5025534 02/27/19 02:05 PM
M
MParr Offline
M
Idle time and short trips will dilute your oil. Maybe you should try a little thicker oil. Maybe Mobil 1 5W30 or Quaker State Ultimate Durability.
2019 VW Tiguan SE Now: Factory fill & OEM filter
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: Terryd91] #5025535 02/27/19 02:06 PM
PimTac Offline
The extreme short tripping isn’t helping matters either. It’s beneficial to take the long way sometimes to get the engine in prime operating temperature. Of course, that’s easy to say on my part. We all have our schedules to keep.
I do agree on the Magnatec. There have been quite a few favorable analyses posted here with that oil.
2017 Mazda CX5
Roki OEM filter.
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: Terryd91] #5025545 02/27/19 02:13 PM
T
Terryd91 Offline OP
T
We have been taking more trips to Detroit for camper and boat shows which are 120-160 miles round trip so that might help. With the brutal cold we had the last few months getting this thing hot would take a few trips to work. Now that we are above zero i haven't been using the remote start much so hopefully that helps. I think i'll change it again at 3k this time which should be right before camping season.
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: doyall] #5025645 02/27/19 03:23 PM
P
Patman Offline
Global Moderator
Global Moderator
P
This is what I don't understand. Blackstone makes a ton of money, being as it's probably the number one oil analysis lab around, so why don't they use the proper method for testing for fuel dilution??
2018 Corvette, 14k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 151k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,117k, GC 0w40 & Fram Ultra
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: Patman] #5025655 02/27/19 03:30 PM
K
kschachn Offline
K
I'm going to guess it is because of the cost of the equipment. Gas chromatographs are not cheap, plus there is ongoing upkeep as well as operator training especially in regards to interpretation. They probably don't need a GC for any thing else.
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 281K
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: Terryd91] #5025685 02/27/19 04:05 PM
T
Terryd91 Offline OP
T
If people are still using them for UOA's they probably figure there isn't a need. Like everything in business cost vs return is king.
I may do two sample next time for kicks as im interested in what the true fuel % is. Need to research testing alternatives eventually i guess.
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: Terryd91] #5025729 02/27/19 05:05 PM
O
OVERKILL Offline
O
355 flashpoint definitely points to significantly higher than 1.5% fuel dilution as others have noted. Use another lab.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: 2017 f150 3.5l ecoboost, Pennzoil Platinum 5w30 5.7k mi [Re: Terryd91] #5025771 02/27/19 05:48 PM
B
buster Offline
B
Unfortunately those driving conditions are brutal on oil/engines. My commute is <5 miles to work.
2019 Nissan Frontier Pro 4X - 4.0L V6 Factor Fill
Page 1 of 3 1 2 3
