Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 08/23/19 11:32 PM
Castrol 5W50
by Snagglefoot - 08/23/19 11:29 PM
Camry Broke Down
by Nick1994 - 08/23/19 10:51 PM
Pumpkin Beer
by Capt - 08/23/19 09:26 PM
Possible bad Iridium plug
by Eric Smith - 08/23/19 08:57 PM
Is the 5.7gm engine still made brand new?
by motor_oil_madman - 08/23/19 08:19 PM
Motomaster OEPlus MOPH/MOCH Filters
by gamefoo21 - 08/23/19 07:29 PM
Man's best friend!
by Mad_Hatter - 08/23/19 06:53 PM
2007 Ford Fusion Cam Pics
by tig1 - 08/23/19 05:31 PM
Cloning a Lexus key
by Nayov - 08/23/19 04:23 PM
2011 GMC Acadia Shock/Strut Replacement
by panthermike - 08/23/19 03:49 PM
Confusion on oil to use on BMW 328i 2010
by goldenjava - 08/23/19 03:21 PM
ProSelect 27356 cut open
by Sayjac - 08/23/19 03:04 PM
Electrolux - Dryer reliability warning.
by pezzy669 - 08/23/19 02:37 PM
Microfiber Towels for different applications?
by Quattro Pete - 08/23/19 01:53 PM
Coated vs. painted rotors
by atikovi - 08/23/19 01:13 PM
New spark plugs, occasional misfire
by avacado11 - 08/23/19 12:34 PM
Boogyman, GeoffPD, CabanaBanana, tblack, goldenjava
69048 Registered Users
23 registered members (Char Baby, bmod305, billt460, avi1777, Convert, ctechbob, 4 invisible), 529 guests, and 18 spiders.
Topics293,713
Posts5,045,462
Members69,048
Most Online3,532
Jul 30th, 2019
Mahindra engine oil filter for a 2555 tractor. #5023892 02/25/19 11:28 PM
F
Farmer52 Offline OP
F
I own a 2016, Mahindra 2555 HST tractor. The oil filters for the tractor are expensive. The engine oil filter just cost me around $46.00. This filter, 006016642V91, does not show a cross over replacement. In fact, most of the Mahindra filters don't show a cross reference. The other Mahindra engine oil filter for this tractor is a 006008803F1, an older number that was replaced by the 006016642V91 filter. I took the new filter to my local NAPA store to see if they could find a filter that matched it. They researched the filter and found one that looks very close. The center threads on the filter are 20x1.5 mm. The NAPA Gold filter part number is 1324 and it's under $8.00. The gasket matches up perfectly to the Mahindra. Now I know there is more to a filter than physical appearance. The counter man printed off the spec sheet for the 1324 filter. This filter is used on all types of smaller diesel engines, so I wonder if will be OK to install it on my Mahindra? The Mahindra engine oil filter, part # 006016642V91 is made by Mahle Corp. Their part number is OC 1139. I called Mahle USA and they said they manufacture this filter for Mahindra and it has a copyright on it. No specs are available.
Does anyone have any thoughts on this?
[Linked Image]
Re: Mahindra engine oil filter for a 2555 tractor. [Re: Farmer52] #5023910 02/25/19 11:45 PM
Z
ZeeOSix Offline
Z
If the threads are correct, and the base gasket diameter is basically the same so it mounts well on the motor, then it's going to be fine. Realize that most oil filters are specified for literally 100s of different engines so 99% of the time there is nothing special about the filter for most use cases. About the only thing that could become "special" about a specific filter application is the bypass valve setting, but on that engine I'm sure the NAPA filter (16 PSI bypass valve) will work fine.
Here's the spec sheet for the WIX 51324, which is the same as the NAPA 1324.
http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=29383
Re: Mahindra engine oil filter for a 2555 tractor. [Re: Farmer52] #5023914 02/25/19 11:51 PM
R
rubberchicken Offline
R
Is the same tractor sold in India ? For that amount of money, I wonder if you could contact somebody in India to price out the filter and have it shipped to USA. I find it hard to believe that any farmer in India would pay $46 for a filter. Definitely keep a used filter to be cut open.
Re: Mahindra engine oil filter for a 2555 tractor. [Re: Farmer52] #5023934 02/26/19 12:09 AM
CT8 Offline
That is the filter that crosses to my Kioti tractor. 1324.
Re: Mahindra engine oil filter for a 2555 tractor. [Re: rubberchicken] #5023944 02/26/19 12:31 AM
F
Farmer52 Offline OP
F
Thanks for the comment. Mahindra builds these tractors, like mine, the 2555, in Texas. I don't know how much is actually built there, but the advertise made in the USA. I tried India, but nothing. Mahle Corp, an Indian company, makes these filters. I contacted Mahle USA and they have no specs for these. Everything seems to have a copyright. I suppose the Mahle filter or Mahindra filter would not cost this much if sold in India. Those guys are cheaper than me!
Re: Mahindra engine oil filter for a 2555 tractor. [Re: CT8] #5023945 02/26/19 12:33 AM
F
Farmer52 Offline OP
F
Yes it does. The NAPA Gold 1324 is used on the Kioti diesel, Isuzu diesel, small Ford diesels and a few GM diesels. I didn't see a gas engine listed.
Re: Mahindra engine oil filter for a 2555 tractor. [Re: ZeeOSix] #5023950 02/26/19 12:40 AM
F
Farmer52 Offline OP
F
Thanks ZeeOSix. The filter is a perfect match. NAPA had a test bolt and it fit in both filters. I know it will fit, but will it be OK to use. I'm cheap, but I don't want to trash the engine. With the engine computer, the tractor would shut down before damage could be done. I think Mahindra has it set up where an owner has to buy filters from them and spend big bucks.
Re: Mahindra engine oil filter for a 2555 tractor. [Re: Farmer52] #5023957 02/26/19 01:11 AM
Z
ZeeOSix Offline
Z
Considering that filter is specified for a lot of cars with V8 engines, I'd say it can handle the job on your tractor.
Re: Mahindra engine oil filter for a 2555 tractor. [Re: Farmer52] #5023960 02/26/19 01:25 AM
L
Linctex Offline
L
1324 is also what most all Branson Tractors use.
I use a Napa 7046 on my Mahindra 4110. I think a 1324 would spin right on, I have never tried it.
Re: Mahindra engine oil filter for a 2555 tractor. [Re: Farmer52] #5023962 02/26/19 01:26 AM
L
Linctex Offline
L
It will never happen. It's a good filter that's used on more small diesel tractors than you or I could ever count.
Re: Mahindra engine oil filter for a 2555 tractor. [Re: Farmer52] #5024081 02/26/19 08:39 AM
L
Langanobob Offline
L
Just a minor clarification, Mahle Corp. is a German company. They may have a presence in India but they aren’t an Indian company.
Re: Mahindra engine oil filter for a 2555 tractor. [Re: Langanobob] #5024322 02/26/19 11:58 AM
F
Farmer52 Offline OP
F
Originally Posted by Langanobob
[quote=Farmer52]
Thanks for the clarification. The new Mahindra filter I just bought says made in India by Mahle, so I assumed Mahle was Indian.
Re: Mahindra engine oil filter for a 2555 tractor. [Re: Farmer52] #5025035 02/27/19 01:24 AM
R
R
[quote=Farmer52]
Since I was aware that Mahindra is an Indian company, I just assumed all its tractor products were made in India, which in hindsight was a silly assumption.
Re: Mahindra engine oil filter for a 2555 tractor. [Re: rubberchicken] #5025562 02/27/19 02:20 PM
F
Farmer52 Offline OP
F
rubberchicken, The Mahindra 2555 I bought is made in Texas. I'm not sure how much of it is really made in the USA or just assembled over here. Mahindra is an Indian company and they still build tractors and equipment in India. These tractors don't look like the USA built tractors. I think they use different sheet metal on the USA tractors, so they look more American. Just my thoughts.
Re: Mahindra engine oil filter for a 2555 tractor. [Re: Farmer52] #5025959 02/27/19 08:40 PM
L
Linctex Offline
L
Just assembled from "Crated status" only.... put the wheels and muffler on, battery in, etc.
None of the major mechanical components (engine, trans, etc.) are made (or even assembled) in the USA
My Mahindra isn't Indian at all except for name - - mine is made by TYC tractors in South Korea
