My 92 Cavalier with the 2.2L and 230,700 miles on it has an engine noise. It's had a slight noise for years but recently it's gotten much louder.
The noise is there under engine load but not much at idle in park. If you rev the engine up in park, the noise will be there initially but then goes away.
When driving, you can't hear it when coasting or if you are not giving it much gas.
Here is a video of the noise with the car idling in gear.
https://youtu.be/fvRR4s_cGMc
