Wondering if the dealer service technician actually bought himself cheap SN bulk oil for gasoline engines, then swapped his cheap stuff for the purchased expensive 5w-40 for his own truck. Its a trick as old as the Model T. Another similar trick they use is to put back in 1 quart of dirty used oil and take home the purchased 1 quart of new oil. Stealing.
Originally Posted by CT8
The viscosity seems on the thick side for a gas 5W-30 oil.
No, that is right in the middle of the "30" j300 range.
Originally Posted by claluja
Can't rely on viscosity, because fuel dilution could have lowered it (and cant tell for sure if any fuel dilutuon, because you used Blackstone which doesn"t actually measure fuel dilution).
But the flashpoint was above 400F, so not much fuel in there. And oxidation would raise it some too, especially using an SN bulk gasoline engine oil in there.
However, as overkill said above, doesn't look like T6 5w40 because of the low P and Zn values. T6 generally has over 1000 ppm Zn, and most of time over 1000 ppm P.
Also calcium (& Mg too) was low, probably at the level you find in a bulk SN gasoline oil for sure. True this wasn't T6, or Valvoline Premium Blue either.
Your iron count is not unusual for a new vehicle. Wouldn't worry about that at this point.
Agreed, while 51 ppm is a bit high, no huge problem here. Piston Deposits are likely flaring up some though.
The stealership should pay for a couple of jugs of Valvoline Premium Blue Restore 10w30 which would clean the rings on this. Cummins uses it sometimes on big rigs.
