Interesting read
by double vanos. 07/16/19 10:34 AM
Apollo 11
by Snagglefoot. 07/16/19 09:55 AM
Brake Pad Unboxing and Review
by krismoriah72. 07/16/19 09:40 AM
Limited Slip Additive
by Snagglefoot. 07/16/19 09:39 AM
Future of Chevy Bolt
by Snagglefoot. 07/16/19 09:04 AM
ST6607 on Honda CR-V 2.4L
by MontePrix28. 07/16/19 08:50 AM
2006 4runner Oil Leak After Synthetic
by Lucas_Jones. 07/16/19 08:46 AM
Quiet Small Engine
by Bailes1992. 07/16/19 08:26 AM
2005 C55 AMG oil recommendation
by TinyVoices. 07/16/19 08:26 AM
Uniroyal Tiger Paw Ice and Snow 3 - Reviews?
by Miller88. 07/16/19 08:09 AM
Wix XP oil filter deal
by Randy_R. 07/16/19 06:54 AM
How accurate is the octane rating at the pump ?
by Mr Nice. 07/16/19 06:33 AM
NAPA Presents: A Concert Behind Prison Walls
by GumbyJarvis. 07/15/19 11:35 PM
2019 Dodge Ram Warlock
by buster. 07/15/19 11:04 PM
2014 VW Jetta - transmission service
by gregk24. 07/15/19 10:09 PM
Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai, Weatherdriver77
68670 Registered Users
92 registered members (4WD, 97K15004WD, 928, 1WildPig, 1978elcamino, 87sammy, 9 invisible), 2,085 guests, and 24 spiders.
Topics291,939
Posts5,013,704
Members68,670
Most Online2,967
Mar 10th, 2019
2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM #5022329
02/24/19 04:13 PM
02/24/19 04:13 PM
North Carolina
CEHepp Offline OP
CEHepp  Offline OP
North Carolina
I have a bet with a guy at work that Pennzoil Platinum will have lower wear metals than Mobil1. I’m doing this test on two cars. This is also my first UOA on this vehicle. When I took this sample, I was changing the oil and I am now using Pennzoil Platinum high mileage 5w30 for consistency. Both changes also have one 300mL can of LiquiMoly Motor Oil Saver and MoS2. These numbers are low enough that I don’t see Pennzoil being lower. I’ve got $30 on the Pennzoil being better but we will see.
[Linked Image]
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022332
02/24/19 04:15 PM
02/24/19 04:15 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
That's not the purpose of UOA's, so this is an entirely pointless endeavour. They lack the resolution and repeatability to be used in this manner.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022338
02/24/19 04:18 PM
02/24/19 04:18 PM
North Carolina
CEHepp Offline OP
CEHepp  Offline OP
North Carolina
It is going to get my point across that his belief that Pennzoil makes a terrible oil and my engine will be toast by the time I change the oil is verifiably not true.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022341
02/24/19 04:22 PM
02/24/19 04:22 PM
MN
oil_film_movies Offline
MN
If using a High Mileage motor oil, putting in Motor Oil Saver might swell the seals too much, a double dose of seal conditioners here. Certainly not needed anyway.
I'm suprised the Mobil1 has high calcium like that. I know the High Mileage version isn't dexos1, yet, still, you'd think Mobil would just make this addtive package the same as silver-bottle Mobil1 & just tweak a couple of things in it (seals, viscosity, & zddp maybe).
Iron wear was very good. Your air filter & air path are tightly sealed since silicon is low, just enough silicon to account for normal anti-foam additives. Good viscosity, very clean report.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022344
02/24/19 04:24 PM
02/24/19 04:24 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Pennzoil makes an excellent oil, as does Mobil, which is why I find it curious you felt it necessary to defile it with aftermarket additives shrug
I don't believe that what you are trying to achieve here is within the scope of utility for Used Oil Analysis. You'll likely see some minuscule variance in PPM between the two lubricants, which demonstrates nothing more than both provided adequate performance over the experienced duration. If that was the purpose, then I'd say you succeeded, but that's not what you outlined in the OP with regards to your wager, which could be affected by ambient temperature, dust, driving style...etc.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: OVERKILL] #5022345
02/24/19 04:24 PM
02/24/19 04:24 PM
MN
MN
To within a bell curve it works. Besides, its just a fun bet to make.
Pennzoil Platinum is made by a reputable company just like the M1 so both are decent and well proven.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: OVERKILL] #5022363
02/24/19 04:38 PM
02/24/19 04:38 PM
North Carolina
CEHepp Offline OP
CEHepp  Offline OP
North Carolina
Defile it? It’s engine oil. Not a sacred text.
If you’d honestly like my reasoning for using these additives, I’ll type it below.
I’ve been using MoS2 in every internal combustion engine for as long as I can remember. Knock on wood, I’ve never had a mechanical failure to speak of. Not even oil seals. I believe the MoS2 has something to do with it. I also use this additive in my air compressor and it is measurably quieter. At worst, it’s doing nothing and I’m wasting my money.
This vehicle is the only one I’ve been adding Motor Oil Saver to. And for one big reason. I recently purchased this vehicle and wanted to make sure the valve stem seals are doing their best at keeping oil where it belongs because this vehicle has the most sensitive catalytic converters I’ve ever seen. Even a small amount of oil burning from this engine has time and time again caused converter failures on my customers cars. I aim to prevent that by running this additive a couple of times and then maintaining everything with high mileage oil after I stop using it.
As far as it being a completely scientific test, I never said that it was. It’s just a bet with a coworker that thinks Pennzoil is the worst oil maker on the planet.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022399
02/24/19 05:09 PM
02/24/19 05:09 PM
NJ
buster Offline
buster  Offline
NJ
This is the older version of M1 HM.
2015 Mazda 3 2.0 - Mobil 1 EP 0w20
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022406
02/24/19 05:13 PM
02/24/19 05:13 PM
North Carolina
CEHepp Offline OP
CEHepp  Offline OP
North Carolina
Can’t be too old. It’s from last year. Bought it at WalMart.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022412
02/24/19 05:25 PM
02/24/19 05:25 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
Very Nice wear numbers.
Thanks for posting. thumbsup
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 188k miles
03 Saturn Ion 2.2 L4 5spd 239k miles
PP, PPHM 50/50 5w30
Currently under the influence of oil shocked2
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022422
02/24/19 05:33 PM
02/24/19 05:33 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
OK, but there are plenty of us on here who have never had a failure, even seals, not using it wink
I'd likely be inclined to use a high mileage oil like what you used, or Maxlife, for the seal issue, rather than an additive. My inclination is to use an oil as it is blended and tested, rather than altering the chemistry and potentially affecting its performance.
I'll agree with the intention of your wager, I think he's out to lunch too, I just wanted to ensure you were aware of the limitations and purpose of UOA's. Your use of additives also caught my interest, since they have the potential to affect the results.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022541
02/24/19 07:53 PM
02/24/19 07:53 PM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
One part per million per 1000 miles for iron is pretty low. Not sure if Pennzoil will beat that. Anyway, let’s have some fun with this. laugh
If you want the job done right......do it yourself.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5158169
07/11/19 09:01 PM
07/11/19 09:01 PM
North Carolina
CEHepp Offline OP
CEHepp  Offline OP
North Carolina
I was right grin
[Linked Image]
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5158175
07/11/19 09:13 PM
07/11/19 09:13 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
Save your money, your time, and our time … take up tennis perhaps …
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5158185
07/11/19 09:33 PM
07/11/19 09:33 PM
North Carolina
CEHepp Offline OP
CEHepp  Offline OP
North Carolina
I bet you’re fun at parties.
