Please explain beta ratios. I'm lost.
by tony1679 - 10/16/19 12:45 AM
Is sump pumps necessary?
by joy786 - 10/16/19 12:18 AM
Sensen Struts - Any Good?
by Nick1994 - 10/15/19 11:54 PM
Quiet Oil--Cause?
by jimbrewer - 10/15/19 11:05 PM
IFJF (Chinese Magnefine)
by mcwilly - 10/15/19 10:40 PM
Let the truck warm up?
by Dragon44 - 10/15/19 10:14 PM
6.4L Powerstroke under the knife
by clinebarger - 10/15/19 10:01 PM
Alternatives to SAE 90 gear oil?
by qwerty11 - 10/15/19 09:34 PM
2010 Infiniti G37x Feedback?
by maverickfhs - 10/15/19 09:30 PM
M1 0W20 High Mil 40C visc
by Silver - 10/15/19 09:14 PM
Havoline 6 Qt Box $11.99 / Free Shipping
by Mr_Luke - 10/15/19 09:02 PM
Oil Recommendation for LS7 Z06 Street & Track Usage
by randomhero439 - 10/15/19 08:46 PM
QSUD 0W20 in 5qt jugs
by faltic - 10/15/19 08:41 PM
Mission Impossible: The Giraffe
by MONKEYMAN - 10/15/19 08:20 PM
Alternative to 10w-40 in Rotella?
by qwerty11 - 10/15/19 08:18 PM
Oil Changes and Ramps
by perfect_oil - 10/15/19 07:50 PM
Where to use T4 15W-40 in a 10W-30 World?
by Astro_Guy - 10/15/19 07:37 PM
How Does Toyota Do It?
by lovcom - 10/15/19 07:29 PM
Tar, cast71, bamadog1, jrogahn, DeathByNissan55
69571 Registered Users
33 registered members (Antimatter, amng04, BlakeB, billt460, bmod305, 2 invisible), 859 guests, and 21 spiders.
Topics296,028
Posts5,089,552
Members69,571
Most Online3,532
Jul 30th, 2019
2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM #5022329 02/24/19 04:13 PM
CEHepp Offline OP
I have a bet with a guy at work that Pennzoil Platinum will have lower wear metals than Mobil1. I’m doing this test on two cars. This is also my first UOA on this vehicle. When I took this sample, I was changing the oil and I am now using Pennzoil Platinum high mileage 5w30 for consistency. Both changes also have one 300mL can of LiquiMoly Motor Oil Saver and MoS2. These numbers are low enough that I don’t see Pennzoil being lower. I’ve got $30 on the Pennzoil being better but we will see.
[Linked Image]
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022332 02/24/19 04:15 PM
O
OVERKILL Offline
O
That's not the purpose of UOA's, so this is an entirely pointless endeavour. They lack the resolution and repeatability to be used in this manner.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022338 02/24/19 04:18 PM
CEHepp Offline OP
It is going to get my point across that his belief that Pennzoil makes a terrible oil and my engine will be toast by the time I change the oil is verifiably not true.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022341 02/24/19 04:22 PM
O
oil_film_movies Offline
O
If using a High Mileage motor oil, putting in Motor Oil Saver might swell the seals too much, a double dose of seal conditioners here. Certainly not needed anyway.
I'm suprised the Mobil1 has high calcium like that. I know the High Mileage version isn't dexos1, yet, still, you'd think Mobil would just make this addtive package the same as silver-bottle Mobil1 & just tweak a couple of things in it (seals, viscosity, & zddp maybe).
Iron wear was very good. Your air filter & air path are tightly sealed since silicon is low, just enough silicon to account for normal anti-foam additives. Good viscosity, very clean report.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022344 02/24/19 04:24 PM
O
OVERKILL Offline
O
Pennzoil makes an excellent oil, as does Mobil, which is why I find it curious you felt it necessary to defile it with aftermarket additives shrug
I don't believe that what you are trying to achieve here is within the scope of utility for Used Oil Analysis. You'll likely see some minuscule variance in PPM between the two lubricants, which demonstrates nothing more than both provided adequate performance over the experienced duration. If that was the purpose, then I'd say you succeeded, but that's not what you outlined in the OP with regards to your wager, which could be affected by ambient temperature, dust, driving style...etc.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: OVERKILL] #5022345 02/24/19 04:24 PM
O
O
To within a bell curve it works. Besides, its just a fun bet to make.
Pennzoil Platinum is made by a reputable company just like the M1 so both are decent and well proven.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: OVERKILL] #5022363 02/24/19 04:38 PM
CEHepp Offline OP
Defile it? It’s engine oil. Not a sacred text.
If you’d honestly like my reasoning for using these additives, I’ll type it below.
I’ve been using MoS2 in every internal combustion engine for as long as I can remember. Knock on wood, I’ve never had a mechanical failure to speak of. Not even oil seals. I believe the MoS2 has something to do with it. I also use this additive in my air compressor and it is measurably quieter. At worst, it’s doing nothing and I’m wasting my money.
This vehicle is the only one I’ve been adding Motor Oil Saver to. And for one big reason. I recently purchased this vehicle and wanted to make sure the valve stem seals are doing their best at keeping oil where it belongs because this vehicle has the most sensitive catalytic converters I’ve ever seen. Even a small amount of oil burning from this engine has time and time again caused converter failures on my customers cars. I aim to prevent that by running this additive a couple of times and then maintaining everything with high mileage oil after I stop using it.
As far as it being a completely scientific test, I never said that it was. It’s just a bet with a coworker that thinks Pennzoil is the worst oil maker on the planet.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022399 02/24/19 05:09 PM
B
buster Offline
B
This is the older version of M1 HM.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022406 02/24/19 05:13 PM
CEHepp Offline OP
Can’t be too old. It’s from last year. Bought it at WalMart.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022412 02/24/19 05:25 PM
rollinpete Offline
Very Nice wear numbers.
Thanks for posting. thumbsup
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 188k miles
03 Saturn Ion 2.2 L4 5spd 239k miles
PP, PPHM 50/50 5w30
Currently under the influence of oil shocked2
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022422 02/24/19 05:33 PM
O
OVERKILL Offline
O
OK, but there are plenty of us on here who have never had a failure, even seals, not using it wink
I'd likely be inclined to use a high mileage oil like what you used, or Maxlife, for the seal issue, rather than an additive. My inclination is to use an oil as it is blended and tested, rather than altering the chemistry and potentially affecting its performance.
I'll agree with the intention of your wager, I think he's out to lunch too, I just wanted to ensure you were aware of the limitations and purpose of UOA's. Your use of additives also caught my interest, since they have the potential to affect the results.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5022541 02/24/19 07:53 PM
Snagglefoot Online Content
Online Content
One part per million per 1000 miles for iron is pretty low. Not sure if Pennzoil will beat that. Anyway, let’s have some fun with this. laugh
If you want the job done right......do it yourself.
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5158169 07/11/19 09:01 PM
CEHepp Offline OP
I was right grin
[Linked Image]
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5158175 07/11/19 09:13 PM
4WD Offline
Save your money, your time, and our time … take up tennis perhaps …
Re: 2008 Volvo XC90 3.2 - 7,018 miles on oil - Mobil1 5w30 HM [Re: CEHepp] #5158185 07/11/19 09:33 PM
CEHepp Offline OP
I bet you’re fun at parties.
