17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
Bought out phone lease for a song
by 14Accent. 07/17/19 02:54 PM
Do you have a fave RTV sealant you use?
by ZZman. 07/17/19 01:36 PM
Scanner
by tiger862. 07/17/19 12:36 PM
Hyundai ELantra ATF follow up
by flinter. 07/17/19 10:14 AM
Poor Bill
by 4WD. 07/17/19 10:05 AM
Cadillac parked for 25 years...
by mattwithcats. 07/17/19 09:52 AM
Sumitomo Encounter Tires
by parshisa. 07/17/19 09:40 AM
API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
prof_redbeard, drnc, blackseven, EdK, guru2019
68686 Registered Users
109 registered members (53' Stude, 1ofeverything, ad244, 4WD, AlienBug, Alfred_B, 10 invisible), 2,319 guests, and 24 spiders.
Topics291,994
Posts5,014,816
Members68,686
Most Online2,967
Mar 10th, 2019
Grease history for post hole digger #5021549
02/23/19 09:06 PM
02/23/19 09:06 PM
Oklahoma
65f100 Offline OP
65f100  Offline OP
Oklahoma
I am in the process of rebuilding a vintage 3-point attached PTO driven post hole digger. It is a Danuser model F8. From old manuals that can be found online it called for Texaco Marfak #1 grease. The next more modern recommendation from the manufacturer was Texaco Multifak #2 grease. The most recent recommendation is Shell Gadus S2 V220 grease (Shell Alvania EP2 Grease). The stated capacity is 3 pounds. I am using Chevron Multifak EP 2. If anyone is rebuilding one of these too, I can post the Timken bearing numbers and seal numbers.
Re: Grease history for post hole digger [Re: 65f100] #5021624
02/23/19 10:05 PM
02/23/19 10:05 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Is the grease got the gear case or the drive line?
2015 F150 2.7
2018 F350 6.2
Re: Grease history for post hole digger [Re: 65f100] #5021682
02/23/19 10:51 PM
02/23/19 10:51 PM
Oklahoma
65f100 Offline OP
65f100  Offline OP
Oklahoma
The grease goes inside the gearbox. It looks similar to a truck rear end inside.
[Linked Image]
[Linked Image]
Re: Grease history for post hole digger [Re: 65f100] #5021786
02/24/19 05:00 AM
02/24/19 05:00 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Huh...... I just keep mine filled with used 15W-40 tractor oil.
I've never thought about putting grease in it.
Re: Grease history for post hole digger [Re: 65f100] #5021979
02/24/19 10:32 AM
02/24/19 10:32 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Look into John Deere corn head grease I have a post hole digger and brush hog and they use 80w 90 gear oil.
2015 F150 2.7
2018 F350 6.2
Re: Grease history for post hole digger [Re: 65f100] #5022008
02/24/19 11:00 AM
02/24/19 11:00 AM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
Looks like it should last a long time. Are you replacing the bearings or just cleaning them up?
Re: Grease history for post hole digger [Re: 65f100] #5022286
02/24/19 03:13 PM
02/24/19 03:13 PM
Oklahoma
65f100 Offline OP
65f100  Offline OP
Oklahoma
I replaced all the bearings and seals. It had gotten water inside and pitted the roller bearings and races.
