Freedom 95 furnace doesn't keep house warm long
by laoshanren - 10/22/19 11:36 PM
2006 Altima 2.5 oil leak
by LeakySeals - 10/22/19 10:34 PM
fishing licenses on boats
by motor_oil_madman - 10/22/19 10:16 PM
Tokyo Motor Show 2019
by PimTac - 10/22/19 10:14 PM
More Quick Chargers
by Snagglefoot - 10/22/19 09:48 PM
'08 Chrysler Sebring Test Drive
by Fifth87 - 10/22/19 08:42 PM
Testing old coolant
by ARB1977 - 10/22/19 08:20 PM
Pennzoil Maximum Power 0W30
by HoosierJeeper - 10/22/19 07:44 PM
Bought a unknown air rifle and need help.
by jakewells - 10/22/19 07:26 PM
What happens to used cars that don't sell?
by WhyMe - 10/22/19 07:11 PM
No spark
by Eric Smith - 10/22/19 06:57 PM
So you need a new engine?
by Skippy722 - 10/22/19 06:40 PM
Super Hot Fish at local fish monger restaurant
by Cujet - 10/22/19 06:39 PM
Mobil 1 5w30 SN+ D1G2 VOA
by donnyj08 - 10/22/19 06:07 PM
flyyamata, laoshanren, Vincenze, Alex_CB300R_ABS, TSOC
69652 Registered Users
35 registered members (AurionX2, AlienBug, caravanmike, Brad_C, Bailes1992, Aredeeem, 4 invisible), 877 guests, and 24 spiders.
Topics296,364
Posts5,096,365
Members69,652
Most Online3,532
Jul 30th, 2019
Grease history for post hole digger #5021549 02/23/19 09:06 PM
6
65f100 Offline OP
6
I am in the process of rebuilding a vintage 3-point attached PTO driven post hole digger. It is a Danuser model F8. From old manuals that can be found online it called for Texaco Marfak #1 grease. The next more modern recommendation from the manufacturer was Texaco Multifak #2 grease. The most recent recommendation is Shell Gadus S2 V220 grease (Shell Alvania EP2 Grease). The stated capacity is 3 pounds. I am using Chevron Multifak EP 2. If anyone is rebuilding one of these too, I can post the Timken bearing numbers and seal numbers.
Re: Grease history for post hole digger [Re: 65f100] #5021624 02/23/19 10:05 PM
CT8 Offline
Is the grease got the gear case or the drive line?
2015 F150 2.7
2018 F350 6.2
Re: Grease history for post hole digger [Re: 65f100] #5021682 02/23/19 10:51 PM
6
65f100 Offline OP
6
The grease goes inside the gearbox. It looks similar to a truck rear end inside.
[Linked Image]
[Linked Image]
Re: Grease history for post hole digger [Re: 65f100] #5021786 02/24/19 05:00 AM
L
Linctex Offline
L
Huh...... I just keep mine filled with used 15W-40 tractor oil.
I've never thought about putting grease in it.
Re: Grease history for post hole digger [Re: 65f100] #5021979 02/24/19 10:32 AM
CT8 Offline
Look into John Deere corn head grease I have a post hole digger and brush hog and they use 80w 90 gear oil.
2015 F150 2.7
2018 F350 6.2
Re: Grease history for post hole digger [Re: 65f100] #5022008 02/24/19 11:00 AM
L
Langanobob Offline
L
Looks like it should last a long time. Are you replacing the bearings or just cleaning them up?
Re: Grease history for post hole digger [Re: 65f100] #5022286 02/24/19 03:13 PM
6
65f100 Offline OP
6
I replaced all the bearings and seals. It had gotten water inside and pitted the roller bearings and races.
