19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
Fridge and freezer oil test
by jkhawaii - 01/17/20 06:59 PM
Not on sale but theeeeeeyyyyy're here!
by jayjr1105 - 01/17/20 06:47 PM
Valvoline Daily Protection 5w30 - $13.52 at Walmart
by RonRonnster - 01/17/20 06:39 PM
Gotta love Friday
by 53' Stude - 01/17/20 06:11 PM
It was 1911
by CourierDriver - 01/17/20 06:10 PM
Desulfating a Battery
by 5AcresAndAFool - 01/17/20 05:41 PM
weird deal alert: potassium permanganate
by GON - 01/17/20 04:42 PM
Kirkland Signature 0W-20 any good?
by CB22 - 01/17/20 04:31 PM
F250 airbox
by mobilaltima - 01/17/20 04:10 PM
Security Camera upgrade
by KrisZ - 01/17/20 04:08 PM
AC Delco PF64 discrepancies??
by metroplex - 01/17/20 03:49 PM
Walmart PP 5w-30 $16.39, won't last long
by Matt1980 - 01/17/20 03:37 PM
Detroit Axle brake pad photos
by 14Accent - 01/17/20 02:10 PM
Ford sent me a refund cheque!
by KGMtech - 01/17/20 02:04 PM
Carter fuel pump removal?
by motor_oil_madman - 01/17/20 01:57 PM
Non-DEXOS or manufacturer oil; voided warranties?
by MrGoodwrench - 01/17/20 01:41 PM
Toyota 4 speed auto trans
by JLTD - 01/17/20 12:55 PM
Australia and Fires
by CourierDriver - 01/17/20 12:09 PM
CPA1989, myisland, BuellRacer, devharryc, UncleNorby
70460 Registered Users
102 registered members (53' Stude, 5AcresAndAFool, 2004tdigls, 67ZL1, 77GrandPrix, 13 invisible), 2,180 guests, and 37 spiders.
Topics300,252
Posts5,171,718
Members70,460
Most Online3,728
Jan 11th, 2020
Grease history for post hole digger #5021549 02/23/19 08:06 PM
6
65f100 Offline OP
6
I am in the process of rebuilding a vintage 3-point attached PTO driven post hole digger. It is a Danuser model F8. From old manuals that can be found online it called for Texaco Marfak #1 grease. The next more modern recommendation from the manufacturer was Texaco Multifak #2 grease. The most recent recommendation is Shell Gadus S2 V220 grease (Shell Alvania EP2 Grease). The stated capacity is 3 pounds. I am using Chevron Multifak EP 2. If anyone is rebuilding one of these too, I can post the Timken bearing numbers and seal numbers.
Re: Grease history for post hole digger [Re: 65f100] #5021624 02/23/19 09:05 PM
CT8 Offline
Is the grease got the gear case or the drive line?
2015 F150 2.7
2018 F350 6.2
Re: Grease history for post hole digger [Re: 65f100] #5021682 02/23/19 09:51 PM
6
65f100 Offline OP
6
The grease goes inside the gearbox. It looks similar to a truck rear end inside.
[Linked Image]
[Linked Image]
Re: Grease history for post hole digger [Re: 65f100] #5021786 02/24/19 04:00 AM
L
Linctex Offline
L
Huh...... I just keep mine filled with used 15W-40 tractor oil.
I've never thought about putting grease in it.
Re: Grease history for post hole digger [Re: 65f100] #5021979 02/24/19 09:32 AM
CT8 Offline
Look into John Deere corn head grease I have a post hole digger and brush hog and they use 80w 90 gear oil.
2015 F150 2.7
2018 F350 6.2
Re: Grease history for post hole digger [Re: 65f100] #5022008 02/24/19 10:00 AM
L
Langanobob Offline
L
Looks like it should last a long time. Are you replacing the bearings or just cleaning them up?
Re: Grease history for post hole digger [Re: 65f100] #5022286 02/24/19 02:13 PM
6
65f100 Offline OP
6
I replaced all the bearings and seals. It had gotten water inside and pitted the roller bearings and races.
