What makes a good forever car?
by Kurtatron. 07/19/19 05:03 AM
BMW LL04 Dissapeering?
by Bailes1992. 07/19/19 03:51 AM
Which Synthetic Oil Do You Use, And Why?
by BlueOvalFitter. 07/18/19 10:50 PM
do laptop batteries really go bad or
by WhyMe. 07/18/19 10:32 PM
2016-2017 Chevy Equinox reliability
by gregk24. 07/18/19 10:12 PM
Mann HU816 x
by IllinoisSparky. 07/18/19 09:41 PM
Seafood Combo
by vavavroom. 07/18/19 09:37 PM
‘13 Silverado 1500 Extended Cab
by parshisa. 07/18/19 09:35 PM
Where to have a watch serviced?
by E150GT. 07/18/19 08:32 PM
Stubborn diff fill plug
by HoosierJeeper. 07/18/19 08:21 PM
Big score on auto parts clearance AAP
by Marco620. 07/18/19 08:05 PM
Would this cause my jeep to stall?
by MileHigh18. 07/18/19 08:00 PM
Looking for Highlander '06,'07, '09
by Gebo. 07/18/19 06:39 PM
'03 F150 Parking Brake Adjustment
by benjamming. 07/18/19 06:17 PM
Do You Still Change Your Oil at 3K?
by Gebo. 07/18/19 05:33 PM
Any sellers on amazon for Honda A02?
by BTLew81. 07/18/19 03:44 PM
First SMR (MMR) slated to be built at Chalk River
by OVERKILL. 07/18/19 03:31 PM
Torque Specs for 2004 Dodge Ram transfer case
by diyjake. 07/18/19 02:15 PM
Raunper, OilDrinkingHemi, suuru, Hollicrev, Richb55
68704 Registered Users
46 registered members (Bailes1992, Astro14, 87sammy, AlienBug, askani79705, 324Matt, 9 invisible), 740 guests, and 21 spiders.
Topics292,062
Posts5,016,125
Members68,704
Most Online2,967
Mar 10th, 2019
5w30 in K20A3? #5020978
02/23/19 09:48 AM
02/23/19 09:48 AM
Canada
OCDriver Offline OP
OCDriver  Offline OP
Canada
When I first changed oil in the Civic SiR (Canadian model) I picked up last year, I put in PP 5w20 High Mileage. They usually have Mobil1 as well, but I think they (Canadian Tire) were out of stock at the time. I'm sure either one is just fine.
The manual states that it can accept 5w30, but should switched back to 5w20 when possible. I've read a number of things about 30 being better for the cams, Honda's only recommending 20 because of CAFE, etc. I saw another thread with UOA/VOA's showing that Mobil1 0w20 actually pushes close to a 30 (I'm not sure if that applies to the H/M formula, though).
Wondering if it's beneficial to just run a 30? Maybe 5w30 in summer and 0w20 or possibly 0w30 winter?
Re: 5w30 in K20A3? [Re: OCDriver] #5021020
02/23/19 10:49 AM
02/23/19 10:49 AM
CO
JLTD Offline
JLTD  Offline
CO
Since it is listed as acceptable, and you have data that a 30 is better for cam wear, I'd go 0w-30 all year and agree the 20 is for CAFE.
I use the overseas manual to choose my oil viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 149k, SS5w30/Amsoil
His: 2015 4Runner 55k, SS 5w20/Amsoil
Re: 5w30 in K20A3? [Re: OCDriver] #5021038
02/23/19 11:15 AM
02/23/19 11:15 AM
Ohio
TurboLuver Offline
TurboLuver  Offline
Ohio
I run 0w-40 in my K20Z3.
Re: 5w30 in K20A3? [Re: OCDriver] #5021129
02/23/19 12:50 PM
02/23/19 12:50 PM
Alberta
carviewsonic Offline
Alberta
I've got 1 each of M1 5w20, 0w20, and 5w30 for my Accord to use up, bought on sale at different times. After that I'm just going with M1 0w30 year round, since I'm starting to occasionally see it on sale now too. I figure a 0w30 will theoretically be a bit better for severe low or high temps.
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: 5w30 in K20A3? [Re: OCDriver] #5021145
02/23/19 01:11 PM
02/23/19 01:11 PM
USA
HowAboutThis Offline
USA
I had the old K20A3 for 15 years before "upgrading" to a new Corolla. If you've driven both cars you'll know why I used quotes 😂😂😂 I used 0w-30 and 5w-30 year round and had a horrible ticking at about 50k miles. Exhaust cam lobes gone. It was bad metallurgy from factory, is what I heard. Replaced exhaust cam, ran everything from 0w-20 to 5w-40 for the next 150k miles. No cam issues. Just bad seatbelt sensors, brake calipers seizing, and idler pulley bearing.
So, in my opinion, use whatever in it. The crappy cams are due to crappy cams, not 5w-20.
Re: 5w30 in K20A3? [Re: OCDriver] #5021362
02/23/19 05:17 PM
02/23/19 05:17 PM
War Eagle
toneydoc Offline
toneydoc  Offline
War Eagle
Just use 0w30 year round and do not worry about changing back and forth between the two oils
1994 Jeep 164k Castrol Synblend 10w30
2014 Camry 40k Castrol Magnatec 0w20
2018 Jeep Cherokee 5k Pennzoil Platinum 5w30
2014 HD Ultra 49k Mobil1 15w50
2012 Rav4 40k Mobil 1 0w20
Re: 5w30 in K20A3? [Re: OCDriver] #5021611
02/23/19 09:52 PM
02/23/19 09:52 PM
montreal ,canada
madeej11 Offline
madeej11  Offline
montreal ,canada
I'd go with Pennzoil Platinum 5w30. Year round mind you, no need to change oil weight for the winter. I believe PP is a lighter 5w30.
Re: 5w30 in K20A3? [Re: madeej11] #5022364
02/24/19 04:39 PM
02/24/19 04:39 PM
CA
jeff8407 Offline
jeff8407  Offline
CA
Honda K series engines typically like a viscosity on the lower end of the scale (5-20, 0-20). The slightly thinner oil helps the spool valve actuate the VTEC system a bit faster. But, the real issues are cavitation with the oil pump/pick up(above 8500 rpm) and oil starvation to the last cam tower at sustained high RPM--the thinner oils help increase the flow/volume to a certain extent.
Since our poster has the K20A3, he doesn't have to worry about the spool valve or vtec, or turning the engine much above 7K--hence, 0-30 oil would be an excellent choice.
Re: 5w30 in K20A3? [Re: jeff8407] #5022451
02/24/19 06:04 PM
02/24/19 06:04 PM
Ohio
TurboLuver Offline
TurboLuver  Offline
Ohio
Looks like the European oil specs clearly state NOT to use a 20w, at least on the 06-11 high revving K series
Euro Oil Spec
Re: 5w30 in K20A3? [Re: jeff8407] #5024700
02/26/19 06:13 PM
02/26/19 06:13 PM
Canada
OCDriver Offline OP
OCDriver  Offline OP
Canada
I'm not familiar with the exact mechanisms of VTEC, but the A3 does have a sort of VTEC "light" that only applies VVT to the intake valves and not the exhaust. There's no distinct switchover in the rev range.
Re: 5w30 in K20A3? [Re: OCDriver] #5024756
02/26/19 07:18 PM
02/26/19 07:18 PM
Canada
OCDriver Offline OP
OCDriver  Offline OP
Canada
Too late to edit. Did some light reading on the i-VTEC system in my car. It only applies VVT to the intake valves, but it is still an oil-driven mechanism.
So, I'm thinking I'll stick with 20, but I'll switch to one on the heavier side. Suggestions? I'd prefer to stick with a high mileage formula if possible.
This thread shows a VOA suggesting that M1 makes a thick 20, but that was over 15 years ago (!!!).
Re: 5w30 in K20A3? [Re: OCDriver] #5025032
02/27/19 01:19 AM
02/27/19 01:19 AM
Suomi
Bjornviken Offline
Bjornviken  Offline
Suomi
Honda runs best on xx-30 grades. According to my experience with honda engines.
And Honda EU spec is xx-30 for cars. 10w-30 for motorcykle and marine engines.
