Outlasted 3 Marriages
by Y_K - 12/08/19 10:10 PM
High miles on 0W20 oils?
by EyesofThunder - 12/08/19 10:02 PM
90 350 intake gaskets and sealant
by P10crew - 12/08/19 10:01 PM
Glock Polymer80
by pkunk - 12/08/19 09:59 PM
Reman steering rack 09 CRV
by Chester11 - 12/08/19 09:24 PM
Edge 5W-30 10k miles '13 F150 5.0
by dustyroads - 12/08/19 09:18 PM
Hyundai engine failures getting news again
by OVERKILL - 12/08/19 09:04 PM
2015 Ford Fiesta ST
by daemontrym - 12/08/19 07:39 PM
NVX NSP65 Speaker review: Good deal!
by 14Accent - 12/08/19 07:26 PM
Thanks to Quattro Pete for making the 2020 avatars!
by wwillson - 12/08/19 07:17 PM
Klotz 2 Stroke Smelling Candle
by FA_WRX - 12/08/19 06:31 PM
Red 1998 Honda Civic DX 2DR HATCH - STOLEN - FRESNO CA
by Deliverance95345 - 12/08/19 05:40 PM
Non scientific oil test.
by tblt44 - 12/08/19 05:33 PM
Nitromethane prices
by 53' Stude - 12/08/19 05:31 PM
Question about JASO specs?
by frascati - 12/08/19 04:15 PM
Anyone knows outdoorsy magazine that are US only?
by MoneyJohn - 12/08/19 03:54 PM
Did Honda discontinue PSF
by iluvhonda - 12/08/19 02:44 PM
02 Silverado 5.3L LT Gas fill issue
by Gito - 12/08/19 02:30 PM
Quick Strut Advice
by coopns - 12/08/19 02:24 PM
Dq380/381 7sp wet clutch dsg
by SkodaPANDA - 12/08/19 02:18 PM
redradar, Jonas_K, slxgold, Dennisfly, AutopartsTester8
70070 Registered Users
57 registered members (2strokeNorthstar, AC1DD, asiancivicmaniac, bdcardinal, BlakeB, allepunta, 4 invisible), 1,167 guests, and 29 spiders.
Topics298,469
Posts5,136,057
Members70,070
Most Online3,589
Nov 2nd, 2019
Grease history for post hole digger #5021549 02/23/19 08:06 PM
6
65f100 Offline OP
6
I am in the process of rebuilding a vintage 3-point attached PTO driven post hole digger. It is a Danuser model F8. From old manuals that can be found online it called for Texaco Marfak #1 grease. The next more modern recommendation from the manufacturer was Texaco Multifak #2 grease. The most recent recommendation is Shell Gadus S2 V220 grease (Shell Alvania EP2 Grease). The stated capacity is 3 pounds. I am using Chevron Multifak EP 2. If anyone is rebuilding one of these too, I can post the Timken bearing numbers and seal numbers.
Re: Grease history for post hole digger [Re: 65f100] #5021624 02/23/19 09:05 PM
CT8 Offline
Is the grease got the gear case or the drive line?
Re: Grease history for post hole digger [Re: 65f100] #5021682 02/23/19 09:51 PM
6
65f100 Offline OP
6
The grease goes inside the gearbox. It looks similar to a truck rear end inside.
[Linked Image]
[Linked Image]
Re: Grease history for post hole digger [Re: 65f100] #5021786 02/24/19 04:00 AM
L
Linctex Offline
L
Huh...... I just keep mine filled with used 15W-40 tractor oil.
I've never thought about putting grease in it.
Re: Grease history for post hole digger [Re: 65f100] #5021979 02/24/19 09:32 AM
CT8 Offline
Look into John Deere corn head grease I have a post hole digger and brush hog and they use 80w 90 gear oil.
Re: Grease history for post hole digger [Re: 65f100] #5022008 02/24/19 10:00 AM
L
Langanobob Offline
L
Looks like it should last a long time. Are you replacing the bearings or just cleaning them up?
Re: Grease history for post hole digger [Re: 65f100] #5022286 02/24/19 02:13 PM
6
65f100 Offline OP
6
I replaced all the bearings and seals. It had gotten water inside and pitted the roller bearings and races.
