Originally Posted by billt460
I rented a Rug Doctor from Home Depot the last 2 times we spot cleaned our carpets. But I'm not that thrilled with it to do it a third time. What is the best rental machine? Or are they all the same?
Go to Lowe's and rent the Bissel Big Green carpet cleaner. It cleans in both directions instead of just one like the Rug Doctor. The only thing I didn't like about it is the weight esp when full of cleaning solution. Does a great job cleaning and drying.
I would then go to Home Depot and buy some Zep Premium carpet cleaner. Not only does it clean but also leaves some protection behind. So the next cleaning should be easier. Make sure you get the Premium cleaner since they make a regular version also. Trav recommended the cleaner which is how I found out about it. Below is a $5 off coupon for the machine rental. About $35 for the cleaner and machine rental total for a 24 hour rental. When you see all the black water that is extracted you know it was worth it.
https://www.bissellrental.com/Custo...Eka_Q4AIVBLbACh3tngf6EAAYASABEgI0kPD_BwE
