A friend of mine with a Jeep and the 3.6L that is getting up in mileage but well looked after had an injector fail on him a couple of weeks ago. I went through standard diagnostics with him and the injector was definitely bad not putting out fuel at all and another one in the other bank of cylinders was dripping when off.
Given the mileage we decided to put a set of 6 injectors in and ordered them from RockAuto. They arrived and we put them in today. Got the top end all put together (Plennum etc.), fired it up and had a misfire on 4 cylinders. Scratching our heads we took the plenum off again and doubled checked all the connectors to the injectors and coils and couldn't find anything wrong. I pulled the fuel rails and injectors again and put them on my dad's fuel injector test aparatus and sure enough 4 injectors weren't working at all some of the time and intermittently would fire a little bit of fuel.
We tested all the old injectors and picked the best 4 of the 6 and then added the 2 new good ones from the RockAuto order and put the Jeep back together. All good, fired right up and ran perfectly.
So I packaged up the 4 injectors not working and we started the return process with them.
I could understand 1 bad injector in a lot because stuff happens but 4 bad in the same shipment of 6 is just weird. I tested the resistance on the new, existing, and bad injectors and they all had 11.8ohms so it doesn't appear to be an electrical circuit problem but I guess the mechanical part of the injector is sticking.
First time ever I had this problem swapping out injectors.
Anyone else have this issue with RockAuto?
In case anyone is wondering they were Standard Motor Products injectors that came out and that is what we ordered to go back in.
Here is goes.... LOL
