How much gas is in it? Sounds like the pump is sucking air when you hit the grade.
The gauge says there is between 1/3 tank left. It does have a history of gas gauge problems. A year ago it was throwing a code which required the cluster to be rebuilt. There is a relearn procedure for the gauges. Some kind of key / pushing on the trip button dance. I'm going to try that. And I suppose I should probably go to the gas station and fill up a can of Premium.
I really should give up on this thing. Has a problem almost every month. The enticement of fixing a free car tricked me into spending $2,800 in parts and a new set of tires on this troubled car. So I'd like to get a year or two out of it
That'd be where I'd start. Put more gas in it, if the problem goes away you know it is either the gauge or the pick-up in the tank.
I put 5 gallons of gas in the car. Gauge pretty much stayed in the same place. And.. It starts. Drove up and down the street. No issues. Its the gas gauge again!!! But this time different. Before it had a code. This time no codes. So the suspect would be something mechanical?
Glad I could be of assistance
Could be a stuck float. See if rapping the tank changes the reading.
