Originally Posted by NH73
I got a 2004 Ford Explorer Sport Trac with 102,600 miles. The rear brakes are running low and likely won't pass next inspection. The last inspection the right rear took on some significant wear compared to the year before. Would that mean its time for caliper replacement? What calipers would you recommend? I thought about Raybestos Element3.
Sorry I don't have any experience with Element3 calipers. I have had good luck with NAPA rebuilt calipers.
Funny, I've been considering pre-emptive rear caliper replacement on the 2005 Pilot when putting on the new set of pads and rotors I just got. Normally I wait until stuff actually breaks or malfunctions. But my last set of rotors and pads are meeting an early end because the caliper pins got washed dry and stuck, and even though that's fixed and the brakes work OK, they sound swishy all the time and grindy when used, the usual symptoms of pads that have tilted in use. So I also have all-new pins and boots I'm throwing on with the pads and rotors. Soon.
So that got me thinking, the only thing left is hoses and calipers and I'll have all-new brakes. So I checked and genuine Honda rear brake hoses are only $34 a pair plus shipping at Majestic. Deal! So I ordered some. Calipers, of course, are much more, new or rebuilt.
But then I'm thinking some more, if the calipers go out on me (I was reading the phenolic caliper piston thread), this set of pads & rotors might meet an early demise just like the current set. If I just toss some rebuilt calipers on there I may go to end of life without touching the rear brakes again, well, except for the annual check, clean and re-grease.
But now I have more time to think about it. As of this weekend the Honda is having new transmission problems. So I'm not doing jack on the brakes until that is sorted out. I may have just reached end of life anyway.
What about rotor and pads?
I highly recommend the combination of NAPA Ultra Premium and AdaptiveOne brake pads, they are doing great on the front of my Pilot, but wow are they pricey. I don't recommend Wagner ThermoQuiet pads, as they have failed to be quiet, feel a bit spongy, and are just OK pads at a premium price.
But for the rears of my Pilot I just received another option recommended on this board, Raybestos Element3 coated rotors and matching Element3 pads. But I have to wait on actually installing them before I give a full-throated recommendation.
