Originally Posted by artbuc
Don't see any reason to replace everything just because the bulb is cracked. Also, getting a new carb, plug, fuel line, etc for less than $15 tells me quality must be super low. Thx for the link but I would not trust this source.
It's true that the linked kit is aftermarket, and I am certainly in favor of OEM whenever practical/economical. However, at this point i am not convinced that the OEM carbs are superior to aftermarket. In fact, the one i have on my old edger has the same markings as the original. I dont know if it was made as a true replica or what, but it works well. So far I have been running aftermarket carb kits on several pieces of equipment for 6+ years with no problems; originals lasted around 10-15 so too early to tell whether the cheapies will last that long. If they dont last, i will be quick to change my opinion on aftermarket vs oem!
