Originally Posted by Zee09
As a C-Maxer myself if you read customer reviews about low mpg to me it was driver error. ( latest models)
They drive it like a basic car. If you don't let off the gas you will never get that kind of mpg.
You know- let off the gas pedal to get into electric mode and then re-engage- not coast but get into EV mode.
I never try to max MPG in my C-Max by doing the "pulse-n-glide" technique. I beat the EPA MPG sticker all the time, average. Mine gets 44 MPG long term, over about half and half city-highway.
A hybrid like that loves hills. Loves city stop-n-go. Hates steady high speeds on level ground.
I think I score higher than the EPA because I have more hills around.
Main point: The engine is most efficient at a sweet spot of torque & RPM, and the more it operates there, the better.
Ford did make the aero better in the 2015 and later C-Max models, using small tricks, and they also optimized the software's strategy better then the earlier models did at first. It did improve.
